Exedy Clutches CHEAP!!!!
We have several clutches that we are looking to get ride of. Prices are so cheap we can't print. the sale is only until monday.. PM for the best price ever
3 left instock
Exedy Single Plate - Hyper PN EXED MH01SD
he Hyper Single Clutch is engineered to optimize performance for cars that are moderatly modified, but do not require the clutch capacity of a multi-plate clutch. Similar to their multi-plate clutches, it has a forged aluminum cover that is anodized purple. The aluminum cover is stiffer than a stamped cover and therefore allows a higher lever ratio to maintain the pedel efforts at a reasonable level. No clamp load deflection as in a pressed metal type cover
2 left instock
Triple Plate - SR Type EXED MM023SR
For high-powered applications, EXEDY offers twin and triple Multi-Plate clutches. These are designed for hot street action as well as drag, road, and rally racing.
The twin plate clutches are rated for above 500hp to 750hp. The triple plate clutches are rated for up to and over 1000hp (for drag racing applications). Twins come with both sprung damper discs and solid discs. Triples are all solid discs.
Thanks
Vision Imports
3 left instock
2 left instock
Thanks
Vision Imports
