Perrin Electronic Boost Control Solenoid $69.99 Shipped!!
Old Jun 8, 2005 | 10:30 AM
TalonRcR's Avatar
Thumbs up Perrin Electronic Boost Control Solenoid $69.99 Shipped!!
New from Perrin Performance!!
The PERRIN™ EBCS replaces the factory, bleed type, boost control solenoid offering an extremely fast reaction time for accurate boost control.
The EBCS is a huge benefit for consumers with aftermarket ECU's that use the factory solenoid for boost control. EcuTek, Hydra, UTEC, Motec, AEM, Haltech, Unichip (custom programming needs to be done for the EBCS).
Add the EBCS to any aftermarket ECU to provide full electronic boost control without the need to purchase a separate AVC-R or similar external boost controller.
The actuator is operated by a direct acting single solenoid. No boost pressure is pressing on the actuator, therefore no premature boost loss can occur. The EBCS allows a much lower waste gate duty cycle to produce higher boost levels giving tuners more headroom when modifying high horsepower vehicles.
A built in, non locking, manual override allows tuners to physically test the boost controller. The EBCS will work as a replacement solenoid for all popular Electronic boost controllers.
Designed to handle up to 120psi, the EBCS features aluminum and glass reinforce nylon construction including 425degree (temp) fittings and vacuum hoses for high heat resistance.
Running the special for 69.99 shipped normal price is 79$
Click To Order
Thanks for the support guys
Chris
Old Jun 10, 2005 | 01:29 PM
TalonRcR's Avatar
Bump!
Old Jun 14, 2005 | 08:51 AM
TalonRcR's Avatar
Anyone running an AEM or other standalone should have this!!
Chris
Old Jun 15, 2005 | 10:26 PM
Evo_SpeedKing's Avatar
Chris,
I have an "older" Blitz Dual Solenoid EBC (silver box w/ mode & volume dials) but no solenoid, will this solenoid work or do i need to get a different one? SP Engineering (which Blitz NA refered me to) wants $225 + shipping for the replacement solenoid! i want to use this model, but at that cost i'll go a different route. any ideas/suggestions? Thanks! Shawn.
Old Jun 16, 2005 | 05:58 AM
TalonRcR's Avatar
Originally Posted by Evo_SpeedKing
Chris,
yes it should work. Works with profecb's and other electronic boost controllers.
Chris
Old Jun 16, 2005 | 11:18 AM
ok. I talked to Perrin and they said it will work as long as the original does not have the boost sensor built in. any ideas? my mechanic says it will work but it'll be a pain in the *** to wire up...but it sholdn't be, right? thanks for the help!
Old Jun 16, 2005 | 11:29 AM
TalonRcR's Avatar
You just need to hook it up bleed type vs interupt type if your running stock ecu. If your running utec or any other aftermarket engine management you can use the interupt style. It can be plumbed either way.
Chris
Old Jun 16, 2005 | 11:57 AM
QuickEvo's Avatar
Can this solenoid be used to replace the factory solenoid, with the factory ECU?
Old Jun 16, 2005 | 12:25 PM
TalonRcR's Avatar
Yes it can in bleed type setup.
Chris
Old Jun 17, 2005 | 08:45 AM
Chris
thanks for all the info. i will keep this in mind as i am following a couple of other options right now. thanks again!
Old Jun 20, 2005 | 09:10 AM
TalonRcR's Avatar
Chris
No problem ready to ship!!
Old Jun 27, 2005 | 07:55 AM
TalonRcR's Avatar
bump
Old Jun 27, 2005 | 09:15 AM
MalibuJack's Avatar
Is this thing based on a servo controller, or a open/close type solenoid? if its the latter, what makes it superior to the GM solenoid?
Old Jun 27, 2005 | 09:35 AM
MalibuJack's Avatar
Also, does it have the current limiting resistor already built in, so it doesnt get hot when used with the default bleed setup (at idle the car enables the solenoid (100% duty) with the factory ECU and most piggybacks by default)
Old Jun 30, 2005 | 04:09 PM
unknown2's Avatar
Will this solve the Greddy Type S boost controller problem with it not going over 21psi on the high setting.
