Water/Meth Injection kits 400hp $399
Old Sep 22, 2005 | 08:58 PM
  #91
dryad001's Avatar
Originally Posted by Nesiop
I wish there was a step by step install kit for the Evo. I installed my kit last week but somehow the wiring seems to be messed up but looks right according to that diagram. Anyone got one for this specific kit, and mounting places in the Evo? Also how do you know what boost it sprays at since it is a one set max boost? leave the hose detached from the sprayer and drive around and mark what psi it shoots at and turn that little allen screw where you want it?
Having the same problem right now. I figured if I attach a pump to the boost switch and get it to turn on then see at what psi it turns on. Im guessing the switch is set way too high, although it was suppose to be set at 10psi for the manufacturer. I know my wiring is correct because of you ground the 85 pin of the relay the pump fires up, so according to the directions the switch is set too high.
EDIT: I'll have pics soon, right now the trunk looks like poop. If you ran the water line outside of the car there is a space near the fuel lines where it looks another line could be placed the line that came with the kit fits perfectly and locks into place.
And another edit: I'm an idiot, when I was grounding the 85 pin I was using a different ground than I had hooked up to the kit, apperantly the ground I was using for the kit is not a good one, time to re-wire the ground and try again.
Old Sep 22, 2005 | 09:39 PM
  #92
dsm95hybrid's Avatar
Cams
Old Sep 23, 2005 | 06:43 AM
  #93
Nesiop's Avatar
If you could, try and send me pics of the wiring parts maybe point which goes to which etc.
Old Sep 25, 2005 | 05:13 PM
  #94
J8dailo's Avatar
is there any place around the chicago area can install this piece??
Old Sep 26, 2005 | 09:12 AM
  #95
TalonRcR's Avatar
AMS should be able to install it.
Chris
Old Sep 27, 2005 | 08:13 AM
  #96
TalonRcR's Avatar
1 Ready to ship!!
Old Sep 29, 2005 | 01:42 PM
  #97
TalonRcR's Avatar
ttt
Old Sep 30, 2005 | 06:31 AM
  #98
Nesiop's Avatar
Bump still for a better walk through instructions. The install was alright but curious where people mounted the clog detector and boost sensor. How you adjust it, what people used to hodl the tank still and a better wiring diagram. My wiring seems messed up cause it only shoots out fluid when I put a ground to the boost solenoid at idle.
Old Sep 30, 2005 | 08:13 AM
  #99
992gnt's Avatar
That's when it's supposed spray - when the boost switch reaches the set threshold and grounds the circuit. It's not supposed to spray all the time.
Old Sep 30, 2005 | 09:44 AM
  #100
Nesiop's Avatar
I know it isn't but I turned that allen screw down and up to test both and it never started shooting.
Old Sep 30, 2005 | 09:48 AM
  #101
They are only adjustible from 4-15 psi so if even at the lowest setting you werent boosting 4psi+ they it's not going to turn on.
Old Sep 30, 2005 | 02:26 PM
  #102
Nesiop's Avatar
I have boosted 20psi. It stil ldoes not come on.
Old Sep 30, 2005 | 07:48 PM
  #103
dryad001's Avatar
It seems that the boost switch is finicky, make sure you have a good ground from the switch. Then get yourself a bicycle pump and put pressure into the switch if it turns on your set to go. This is where I am still stuck and getting ready to rip it out and switch to the SMC kit.
I have also adjusted the screw all over the place I know I have boost into the line and I know I have a good ground and my wiring is correct, I gave up on this for sanitys sake for another week.
Old Oct 3, 2005 | 09:55 AM
  #104
TalonRcR's Avatar
Call david at 770-931-2139 he will help you with your problem
Chris
Old Oct 3, 2005 | 09:57 AM
  #105
TalonRcR's Avatar
No it is a 1-25 psi adjustable not 4-15
Chris
