Peakboost Turbo System Packages @ AF-Performance!
Old Nov 15, 2005 | 12:38 AM
  #31
Soon 2 B EVIL's Avatar
how much for the dump tube?
Old Nov 15, 2005 | 02:52 PM
  #32
af-performance's Avatar
Originally Posted by HxllxMan
Any idea how much the full kit will cost with the Hydra EMS + map ?
Thx
Not 100% sure... We are still working out pricing.
Kevin
Old Nov 15, 2005 | 02:53 PM
  #33
Originally Posted by 5.slow
Do you have them in stock?
Unfortunatly no.. Let me double check with peak to see if they have any available.
Kevin
Old Nov 15, 2005 | 02:54 PM
  #34
Unfortunatly the dump tube is not offered seperate from the manifold.
Kevin
Old Nov 15, 2005 | 05:43 PM
  #35
dryad001's Avatar
So is the 2675 pricing including the DP or what? Plus what size injectors do you recommend with each different turbo kit.
Old Nov 15, 2005 | 11:45 PM
  #36
Precision 1000's are what is being used by the peakboost Evo8 car. The downpipe is Not included. You would have to make one custom for your setup or purchase the package and wait 2 weeks till the downpipe is released.
They are doing testing with the downpipe diameters etc to see which flows best as well as making sure it fits like a glove and is easy to install.
Thanks
Kevin
AF-Performance
Old Nov 16, 2005 | 07:23 AM
  #37
platinumspecv's Avatar
Does this kit have an option for the dumptube to be circulated back into the downpipe?
Old Nov 16, 2005 | 07:24 AM
  #38
At the moment no. The current kit on the peakboost evo8 has it routed to the bottom of the car. There were boost issues when routing it back. Normally people do this for sound purposes, but at peakboost its all about power. I am sure they will eventually make one, but at the moment its negative..
Kevin
AF-Performance
Old Nov 16, 2005 | 07:41 AM
  #39
JoeWalker4G63's Avatar
Yeah here in NC having an open dump makes for problems at the inspection station. We also have OBD 2 testing instead of tail pip sniffers. Is the Hydra EMS OBD 2 compliant so I will not be hassled at the inspection station?
Old Nov 16, 2005 | 08:46 AM
  #40
evo8_m3's Avatar
would peakboost also offer 02 housing for those alreay have an aftermarket DP (Helix, BR, HKS, etc...) ??
Old Nov 16, 2005 | 05:36 PM
  #41
Yes it is..
Kevin.
Old Nov 16, 2005 | 05:37 PM
  #42
Negative on this since the manifold would sit the turbocharger completly different than that normal downpipe that most use. In order to run the manifold etc, a custom dp will have to be made or the peakboost one once released will have to be purchased.
Kevin
Old Nov 17, 2005 | 11:22 PM
  #43
All peakboost pms are sent.
Old Nov 18, 2005 | 11:17 PM
  #44
ct9a gsr's Avatar
Can we choose what style / bolt pattern we want the turbine housing on a GT35R?
Like... say we want a GT35R w/ a T04S .70ar compressor cover w/ a .82ar turbine housing in a 5-bolt pattern... could that be an option?
What's the pricing most likely going to be on the downpipe PeakBoost plans to produce to mate to this kit?
Will the manifold + turbo fit with the stock radiator and radiator fan?
Will the custom upper coolant pipe come with the started to kit ensure fitment w/ the stock radiator?
Old Nov 19, 2005 | 09:16 AM
  #45
vone750's Avatar
bump
