Helix injectors power pacakges!
Old Nov 21, 2005 | 04:26 PM
Gruppe-S's Avatar
Thumbs up Helix injectors power pacakges!
Helix 720cc injectors - $365 shipped
Helix injectors are custom manufactured in Japan by a world-famous OEM parts manufacture. The injector on-time, spray patter, and flow rate are all carefully matched for maximum power and reliability. In addition, all Helix injectors are carefully flow tested to ensure identical flow rates and top quality.
-Helix design on time and spray pattern for maximum power output
-Manufactured by world renounce O.E.M manufacture
-Cheap and affordable compare to Greddy
-Excellent build quality compared to Lucus made injectors
-Manufactured with easy to scale and tune in mind
-Idle like stock
Sale price: $2499 shipped
ATP Stealth GT Kit:
Tired of getting harassed by the law enforcement? ATP's GT30R turbo kit is designed for those of you who love to frequent the drag strip yet don't want to worry about being harassed by the law enforcement!!! This Stealth Turbo kit is capable of putting down 350+whp with a properly tuned engine management. The kit comes with ATP GT3071r turbocharger that specifically designed to fit the factory exhaust manifold to keep that "Factory" look. Tial poppet-style external wastegate, flanged exhaust downpipes, and all associated hardware for a complete and detailed installation.
Package sale price: $899 shipped
Buddy Club cams:
Buddy Club Racing Spec high performance camshafts are CAD computer designed to optimize torque and horsepower over the widest possible powerband. All Racing Spec camshafts are made from new billets of high nickel content iron alloy, not reground stock units, therefore equaling or exceeding the OE units they are designed to replace in terms of quality and workmanship. The camshafts are direct replacements and are designed to be compatible with the factory followers and valve springs. Buddy Club also offers high performance valve spring sets for limited applications that can benefit from stiffer springs when using “Larger” profile Buddy Club camshafts. It is possible to gain at least 20+ whp with Racing Spec camshafts on turbocharged applications.
Package sale price: $1399 shipped
Mitsubishi T.M.E:
The Mitsubishi RS T.M.E turbocharger uses a titanium aluminize shaft to reduce the shaft weight by an amazing 30%! Together with a much larger 10.5cm turbine housing, this turbo is able to flow quite a bit more air than stock and with the lighter shaft, spool-up is even better than with the stock turbocharger! This is a direct, Mitsubishi made, replacement for your stock turbo to give you an extra boost of power.
Free shipping to any lower 48 states
CA tax apply to CA residents
Thanks,
Tom
Old Nov 21, 2005 | 05:32 PM
carbonevo8's Avatar
how much just for the injectors?
Old Nov 21, 2005 | 06:13 PM
Gruppe-S's Avatar
The injectors are only $365 shipped to any lower 48 states.
Thanks,
Tom
Old Nov 23, 2005 | 10:38 AM
Gruppe-S's Avatar
bump
