Agency Power Christmas Specials
Old Dec 14, 2005 | 03:31 PM
Vivid Racing's Avatar
Agency Power 5 Speed Short Shifter Mitsubishi EVO 03+
Agency Power has always focused on real racing performance. With its strong alliances with some of the fastest EVO VIII's on the tracks, Agency Power has finished testing and is proud to release its brand new short shifter for the 2003 and up Mitsubishi EVO. This 5 speed short shifter is designed to give you a fast, clean, and precise shift that the stock shifter lacks, and the competition tries for.
The shifter reduces the throw about 35% compared to the factory shift lever. In addition, the shifter height is lowered about 15mm for a sport feeling to help you get through the gears more efficiently. The CNC machined short shifter is made from 1018 High Strength Steel. The lever is then zinc coated in black for a stylish stealth look. This short shifter is a perfect addition to your high performance or off the lot Mitsubishi EVO. Whether you are road racing, drag racing, or daily driver this shifter will improve your driving success.
$120 Shipped
Agency Power Adj. Blow Off Valve EVO VIII, MR, RS 03+
Knowing that the EVO has a very sensitive MAF which causes many BOV's not to work correctly, Agency Power turn to its design team to produce the first multi function and fully adjustable Blow Off Valve for the Mitsubishi EVO, 4G63, and other vehicles using 1.25 inch inlet and outlet flanges. Keeping the turbo spooled between shifts, holding boost pressure strong, and giving you adjustability is what the all new Agency Power Blow Off Valve offers you. What makes the Agency Power Blow Off Valve above all others? The AP BOV is made in the USA and designed from the bottom up after analyzing the current market competitors. What we designed was a full T6061 CNC aluminum valve. The sleek body has a smooth round surface anodized with rich stylish colors in Stealthy Black, Show Silver, and Rich Red. The Agency Power text is engraved on the body next to the 50/50 vent plate. The outlet flange is removable and can also work as a full vent to atmosphere position. The base is 1.25 inches in diameter and designed to be used with the factory hoses in the factory position. The brass nipple on the side is ridged to ensure the vacuum hose stays secure and has no leaks. Continuing with style, the top of the valve has the trademark AP logo engraved on the triangle style top which adjusts the valves spring load. This is held in place by a diamond cut lock ring and O ring. The inside of the valve is operated with a piston and steel spring. The spring rate is manufactured to the correct rate for stock to aggressive boost levels. There is O rings inside to provide proper movement and sealing. The Agency Power BOV is a fully adjustable, fully rebuild able, and a completely useful device. The BOV is designed to be used with several different setups. The valve can be set up to vent 100% to the atmosphere or 50/50. This is where 50% of the air is returned to the intake pipe and 50% is vented out. As well, this valve can be setup as a 100% recirculation valve like stock. The valve includes the return line plug as well. We recommend this valve for daily drivers to high boost race cars.
$200 Shipped
Agency Power High Flow Fuel Rail EVO VIII MR 03+
Agency Power has released their new Mitsubishi EVO VIII and MR fuel rail. This fuel rail is a direct replacement for the factory unit. The CNC machined piece is anodized in Agency Power Purple or Red. It fits with the stock fuel pressure regulator and fittings and can be set up to work with aftermarket units as well. The fuel rail also has a location to put an aftermarket fuel pressure gauge with no modification.Why is this Agency Power Fuel Rail better then stock? Well, the AP fuel rail has a wider diameter for fuel flow then stock. As well, the AP rail is designed to fit larger injectors such as Blitz, RC, and other common brands. When upgrading to a larger turbo set up or needing to upgrade your fuel system, the AP rail will accommodate your needs. While keeping stock fitment and performance when additional fuel is not needed, the fuel rail is also a great dress up piece.
$150 Shipped
Agency Power Light Weight Crank Pulley EVO VIII
Agency Power has just released their brand new EVO VIII 4G63 Light Weight crank pulley for the EVO, MR, and RS cars. The pulley is a direct bolt on using the factory belts. The AP pulley weights about 1.1lb compared to the stock pulley weighing in at 4lbs. The weight savings in rotational mass equates to serious performance increases.Don't worry about the stories you have read on "crankwalk" or unbalancing the motor. The factory harmonic balancer reduces engine noise and vibration in the cabin and deleting this will NOT destroy your motor. The pulley is completely safe as a bolt on giving you between 3-6 horsepower and increased throttle response. Tested and used on the VividRacing.com 500HP EVO VIII!
Watch the Agency Power Pulley at work HERE
$105 Shipped
Agency Power Short Ram Intake Kit EVO VIII
Power, Quality, and Fitment. The all-new Agency Power short ram intake kit for your Mitsubishi EVO VIII, MR, and RS is now available. The AP intake kit includes a 6061 aluminum MAF adapter that is 3D machined for high flow, a K&N cone air filter for most horsepower, and an aluminum “L” bracket for easy mounting to factory chassis hole. The Agency Power MAF adapter includes the engraved text of Agency Power as well as hardware to mount the adapter to the factory MAF housing and bracket. This intake kit is great for aftermarket turbo setups, induction pipes, or just wanting more airflow on your stock EVO. The K&N cone filter included has a 4-inch inlet with a 6 inch to 4.5-inch diameter on the cone. The filter is reuseable with any K&N filter charger kit for the life of your car. The K&N brand speaks for itself giving your car the airflow it needs!
$95 Shipped
Agency Power Ti Catback Exhaust Mitsubishi EVO VIII MR 03+
The need for power, quality, and style has once again been executed by Agency Power with their brand new catback exhaust system for the Mitsubishi EVO VIII and MR. This new stainless steel exhaust system features a brilliant titantium muffler with a titanium 4.5” tip etched with the Agency Power logo. The system utilizes T304 stainless steel 3 inch piping TIG welded with ½ inch thick flanges. The system includes the bung for the factory O2 sensor as well. The Agency Power catback exhaust includes strong durable hangers, gaskets, and hardware for a perfect fitment. The catback exhaust will fit to the factory catalytic converter on your 2003 and up Mitsubishi EVO VIII or MR. The exhaust has an angled exit as seen in the pictures for that JDM look. The exhaust will give you up to 12WHP gain (see dyno sheets). The race sound of the exhaust will not drone inside the car but give you that quality tone you desire (listen to sound clip).
$715 Shipped
Agency Power EVO VIII Turbo Kit 500+ HP
Agency Power has finished testing on their all new Turbo Kit for the 2003 and up Mitsubishi EVO VIII, RS, and MR Edition vehicles. The AP turbo kit is designed to offer the consumer several different options for their vehicle needs. The kit is available with a T3/T4 50Trim Turbo for the daily drivers and road racers. As well, the kit is available with a 60-1 Turbo for the customer wanting to do big horsepower numbers in either drag racing or road racing scenarios.
What sets the Agency Power EVO VIII Turbo Kit aside from the competition is its quality, performance, and presentation that has been proven. Originally tested at the famous Willow Springs Raceway in the Vivid Racing EVO VIII, the prototype helped carry the VR EVO to fast lap times placing in the first Subaru, EVO, Mini shootout. With making full boost by 4000 rpm, the 50Trim kit was on its way to success.
Once the final production unit was finished, we took a stock EVO VIII and added some common parts to get our results. Without going over board to gain high numbers, we put together the car with some of the basic upgrades most people do. Products - B&B downpipe, B&B catpipe, JIC 505 catback Exhaust, Turbo XS UTEC, Perrin MBC, HKS 264 Intake and Exhaust camshafts, ARP Head Stud Bolts, Blitz 700cc Injectors, Agency Power Fuel Rail, and Walbro Fuel Pump.
With the new turbo kit installed, we took the EVO VIII to the local All Wheel Drive Dyno Jet facility. Dynoing the stock car at 220 wheel horsepower, we had a good baseline to tune upwards from. Since most vehicles run everyday on 91-octane pump gas, we tuned it with this gas first for a real life number. The 91-octane map at 1.5 bar (23lbs) of boost put down 330 wheel horsepower (429 Crank HP). Once drained, we filled the tank with 109 Unleaded VP Gas and turned up the boost with a retune. The EVO VIII now made 405 wheel horsepower (526.5 Crank HP) and 358.6 ft/lbs of wheel torque.
Now this is our smaller turbo option! With C16 leaded gasoline (most companies test with this), our 50 Trim kits will make close to 425 wheel horsepower safely on the EVO VIII stock engine. With our 60-1 Turbo Kit, you will achieve about 475 wheel horsepower (617.5 Crank HP).
Why is this kit better then the competition? Well first we give you the ability to switch turbos to your performance needs with nothing but the cost of the turbo. This allows you dial your car in for the type of use it is involved in. Second, all of our piping is T304 stainless steel with ½ inch thick flanges. The superior staff at B&B Performance Exhaust assembles the piping, exclusively for Agency Power. Next, we supply high quality and durable SAMCO brand hose couplers. Available in Red, Blue, or Black. These 3 ply silicon hoses do not rip, wear, or fade. We also include stainless steel oil lines for the top and bottom of the turbo. Our bottom line includes screw on flanges for perfect fitment and no leaks. We use a Tial 38mm wastegate with a .7 spring for perfect response. Our custom designed intake tube with recirc fitment works in conjunction with the factory MAF. As well as we provide a short ram intake system that has a 3D machined housing to fit with the MAF and a K&N style cone filter. The intake includes a bracket for firm fitment. Lastly we include all necessary vacuum lines, gaskets, hardware, clamps, and fittings to make this a true bolt on kit. What finally sets us apart from the competition is our presentation.
CALL FOR SPECIAL PRICING!!!
***Free Shipping available only to customers in the 48 states***
Order Now to beat the Holiday Rush!!!
Questions? Orders? PM me or call me at 1.866.44.vivid ext 226 or my cell phone at 602.502.6647. If i do not answer please leave me a message and i will return your call ASAP.
Jacky
Old Dec 21, 2005 | 11:51 AM
Bump 4 Days till Christmas!!!
Vivid Racing
Mar 4, 2005 07:08 PM
Vivid Racing
Dec 30, 2004 02:14 PM
Vivid Racing
Jul 27, 2004 10:54 AM
Vivid Racing
10
Jul 12, 2004 12:29 PM
