*AMS Fuel Pressure Reg. Kit* $275!!
AMS Fuel Pressure Regulator Kit
This kit is designed for anyone running a larger then factory fuel pump and or injectors. Whether you are running too much fuel and need to back off the pressure, or if you are on the edge of your current injectors and need to raise base fuel pressure. This is the system for you!
The kit comes complete with:
# Fuel Lab 1:1 fuel pressure regulator (your choice of color)
# Liquid Fuel Pressure gauge for regulator mounting
# Return line to mate up to the factory steel line
# Line and fittings to bolt up to any stock or stock replacement Fuel rail.
# Mounting plate for FPR
# All hardware needed.
$275.00
$275.00
Originally Posted by WrX Kila
I am going to be putting a 3076r on and 850 injectors. Do I really need this? I see alot of people run injectors without a fuel regualtor. Please let me know.
It's better to be safe than sorry. Running that turbo it would be a good idea.
