Dyno Flash "E FLASH!" now available
Old Jul 24, 2006 | 04:13 PM
  #601
tony_b's Avatar
ok, so I just pulled all the data off the ecu so I could save the data as my stock map in case I ever have to go back. Why will the software not open the saved file?
I also wanted to play around a little with the software before I send the base map to Al but am weary of it in case I screw something up and have to go back.
Old Jul 24, 2006 | 04:14 PM
  #602
RazorLab's Avatar
Make sure you have the .hex extension after the file name. It will not open it without that.
Old Jul 24, 2006 | 04:24 PM
  #603
ant_turbo's Avatar
Go where you saved the file and add a .bin (at the end of the name you saved it as...... Here's a sample (stock9.bin)
Old Jul 24, 2006 | 04:26 PM
  #604
tony_b's Avatar
Thanks! I just figured it out before I came back in.
So, should I use .bin or .hex? Does it matter?
Old Jul 24, 2006 | 04:30 PM
  #605
ant_turbo's Avatar
Arrow
.bin
Old Jul 24, 2006 | 04:32 PM
  #606
RazorLab's Avatar
I guess if .bin works for ant_turbo then both work because I use .hex
Old Jul 24, 2006 | 05:55 PM
  #607
ant_turbo's Avatar
hex or bin
I sent my stock file!! hope to get my tune soon...........
Old Jul 25, 2006 | 09:31 AM
  #608
mtucci's Avatar
Just got my e-flash today. Can't wait to try it out. Thanks Al. And a shout out to Warrtalon for the help as well.
Old Jul 25, 2006 | 06:34 PM
  #609
hondafan's Avatar
well, i threw in a new set of plugs and my eflash today, a little more in the top end, my butt dyno isn't as sensitive as some people's but i also did a few logs with my pocketlogger and all seems well in the timing and AFR. still would like a custom tune sometime though. overall for the price, it's well worth it.
Old Jul 27, 2006 | 06:39 PM
  #610
speedy6963's Avatar
Originally Posted by DynoFlash
I should be able to get your map done this evening
Thanks for your order
Al
Thanks for the GREAT flash
Ran the car last weekend, 12.53 @ 108.56 mph
Mods on car, turbo back exhaust and electronic boost controller
fuel, 93 octane
Old Jul 28, 2006 | 02:42 AM
  #611
Evo_Jay's Avatar
fuel, 93 octane
can you post the full time slip?
Old Jul 28, 2006 | 08:10 AM
  #612
DynoFlash's Avatar
fuel, 93 octane
Great news - glad you enjoy it
I put a lot of time into those maps - double and triple checking everything and they represent some of my best work. Glad its working out well for you !
Old Jul 28, 2006 | 06:56 PM
  #613
Evo_Jay's Avatar
Al, can I get a ECUflash for a 06 WRX. The 06 WRX can be flashed using the 1.3 cable and current ECUFlash software.
Old Jul 28, 2006 | 09:21 PM
  #614
mrich82's Avatar
I think he only does maps for Evo's, but you could probably get a map from a Suby tuner to use with EcuFlash.
Old Jul 28, 2006 | 10:58 PM
  #615
Evo_Jay's Avatar
Umm, Al used to be a Suby tuner and I believe he still is, but your a newb so you probably dont know that.
I know that he sells Eflashes only for the EVO right now, but I was asking him if it was possible to do a EFlash for a suby.
