Backordered Products NOW Available!
Old Jul 20, 2006 | 01:46 PM
TTP Engineering's Avatar
In high demand and low supply, the POWERFLEX front lower motor mount may just be the single best mod you can do to improve your Evo's driveability and handling for the money!
Off a long backorder I have 15 that came in.
This bushing is made from a 80 durometer polyurethane where the OEM rubber bushing is rated at about a 45-50 durometer rubber material (much softer) and the Powerflex kit comes supplied with a specific stainless steel sleeve and a packet of copper grease/anti-seize.
It is a direct replacement for the soft OEM front mount bushing and fits with absolutely no modification. Installation takes about 20 minutes. The most difficult part is removing the factory bushing from the mount. Without a press, you basically have to destroy it to get it out, but once accomplished, the Powerflex bushing fits in easily.
These are going for $47.99 ea and seems that most are able to self-install.
TO PURCHASE THE FRONT LOWER MOUNT, CLICK HERE!
TO PURCHASE THE FRONT SIDES MOUNT COMBO, CLICK HERE!
