Ingalls Dampener $150Shipped!
Hey all we now have Ingalls Engine Dampeners for your application! We are letting them go to your door for $150 shipped!
If you dont know much about them here is some info and pics!
So get on this killer price!
~Ryan
A self-contained elastomeric shock that mounts on brackets between the engine and the chassis. It reduces extreme engine movement and dampens the motion, providing many benefits. The “Stiffy” was originally intended for the sport compact market, but can be used for some Hot Rod applications if it is applied correctly.
Benefits
Greatly improved off-the-line acceleration
Reduced wheel hop
Improved vehicle stability
Reduced shock loads on driveline components
Smoother shifting
Reduced wear on exhaust system joints
Less vibration transmission to the driver compared to polyurethane motor mounts.
Less shock load, compared to torque straps and chains.
Drifting – helps reduce shock loads when wheels gain traction.
Reduces motor movement – decreases the chance of motor parts rubbing against
the hood and frame.
Specifications
Overall length (mount to mount) = 7 inches (+/-1/4 inch adjustment)
Mounting hole size = 10 mm (.3937 … approx. 3/8 inch)
Maximum stroke = +/-3/8 inch (no preload)
Preload adjustment = 0 – 3/16 inch (max stroke = +/- ¼ inch at max preload)
Maximum shock load (momentary) = 2000 lbs.
Maximum continuous load = 500 lbs.
High quality hardened steel reinforced Teflon Heim joints
Body: 6061-T6 Aluminum
Finish: clear silver anodize
Maximum Recommended HP = 500 with Energy Suspension or Solid Mounts
Benefits
Reduced wheel hop
Smoother shifting
the hood and frame.
Specifications
~Ryan
Gruppe-S
Evo 'For Sale' Suspension / Brakes / Handling
75
Oct 9, 2008 10:56 AM
CorSport
12
Mar 12, 2008 04:32 PM
Fizz Autosports
71
Aug 16, 2007 09:03 AM
Fizz Autosports
Mar 15, 2007 09:02 AM
TalonRcR
24
Dec 16, 2005 08:49 AM
