Blitz, Crower, Brian Crower, APS, Invida, Hallman, and more- JSC SPEED
Former Vendor
APS Dual Vent BOV kit
Blitz Dual Drive Blow-Off Valve
Hallman Manual Boost Controllers
DC Sports, Perrin, Invida Downpipes/ Race Pipes
Brian Crower 272/272 and 280/280 Cams
Crower Rods
Crower Rods
WHAT YOU ARE LOOKING FOR? SALES@JSCSPEED.COM
---> ASK FOR PRICES <---
Former Vendor
INSTOCK at JSC Speed
Perrin Universal Progressive PWI-1 Water Injection System
The Perrin PWI-1 Water Injection System is a great addition to any turbocharged or supercharged car. Forced induction cars produce high intake temperatures, which can result in detonation and will cause your ECU to retard ignition timing; reducing power. Water and methanol injection have been around for quite some time, but have not been used to their full potential until recently. Perrin's Progress Water Injection system takes advantage of this technology by releasing a small mist of water and or methanol into the intake charge which results in significantly lower temperatures, more power, and an overall safer engine. The Perrin Progressive Water Injection System releases water based on fuel delivery, instead of an "on/off" switch style commonly found on other systems. This guarantees that you will have the correct mixture of fuel and water to make maximum power at all times. Expect to see horsepower gains in excess of 20whp depending on your setup. The Perrin Water Injection System is great for turbo cars with small intercoolers, or non-intercooled superchargers. There are many safety and warning features integrated into the Perrin PWI-1 Water Injection System so that if a nozzle gets clogged or the tank gets low, there will be no surprises. These warnings are shown on a dash mounted display and with tuning you can have your ECU cut boost, or switch to a safe map (if it has this capability).
Notes: To get the most out of this system, ECU tuning is needed. The Perrin PWI-1 Water Injection System can be used with a stock ECU, most piggyback systems, and full stand alone units. This kit does not include a tank, so you must tap your windshield washer fluid tank, or purchase an alternate reservoir.
JSC Speed
Jul 15, 2008 10:01 AM
JSC Speed
Jul 10, 2008 06:03 PM
JSC Speed
Jan 11, 2007 09:02 AM
JSC Speed
15
Dec 16, 2006 05:30 PM
JSC Speed
Evo 'For Sale' Exterior Styling
81
Oct 27, 2006 02:10 PM
