PE 4G63 RX6R Turbo Setup KIT
Old Mar 28, 2007 | 09:37 AM
JSC Speed's Avatar
Former Vendor
Lancer Evolution 4G63 RX6R Setup KIT
PM FOR PRICES
RX6R, a compact and light weight ball bearing turbine, known for the Formula-1circuit's best choice, is now available through Power Enterprise the largest IHI turbo distributor in the world. Depending on the enginestrength upgrades, it can produce well over 600 wheel HP. The twin inlet exhaust housings and compressor housings can separately be selected and matched to stock to oversized or reinforced engine applications. The gtwin-inlet exhaust housingh is a design for balancing the each cyliderfs exhaust back pressure. The 4G63 RX6R setup kit can be installed on the vehicle types mentioned above with stock intercooler by fabricating your own inlet and intercooler pipings, Application for the CT9A model come with inlet pipe and air filter system (call full kit). Large volume fuel pump and injectors are sold separately Setup Kit consist of RX6R turbo, Stainless EX manifold, Outlet pipe& Front pipe, Waste gate valve, Oil line set Gasket set and hard wares.
The kit includes RX6R turbine, utilizing external waste gate systems. The strong ball bearing firmly supports the turbine shaft all directions makes superior boost response at all ranges due to non-exocentric spinning of blades.
The kit adopts a 76.3mm large diameter exhaust front pipe, which designed to spool the turbine quicker by reducing the exhaust backpressure. Another remarkable feature is returning the exhaust gas come out of the waste gate back into the front pipe, instead of releasing the waste gate gas directly into the atmosphere, to help reduces the noise and eliminates pollutions. The exhaust manifolds are heat-treated for durability and strength against cracks.
Old Mar 28, 2007 | 12:21 PM
Powerman20's Avatar
Kits comes with A/C front pipe for free! thats a $1,400 piece for free! Turbo is full ball bearing. This kit is perfect for time attack and rally cars. IHI design has extremely quick response and spools 500 - 1000 rpm's faster than other turbos on the market. With the quick spooling response you can get in and out of corners substantially faster than other cars with comparable kits.
Old Mar 29, 2007 | 01:11 PM
JSC Speed's Avatar
Former Vendor
Shipping today if you need it!!!!
Old Mar 29, 2007 | 01:14 PM
Vigo's Avatar
At what RPM does it reach 20psi?
Old Mar 29, 2007 | 03:00 PM
Powerman20's Avatar
at about 3300 rpm it reaches full boost
Old Apr 4, 2007 | 05:20 PM
JSC Speed's Avatar
Former Vendor
bump
Old Apr 4, 2007 | 05:26 PM
JSC Speed's Avatar
Former Vendor
bump
Old Apr 4, 2007 | 05:32 PM
Vigo's Avatar
Do you have anymore dyno charts?
Old Apr 4, 2007 | 06:37 PM
hks-evo's Avatar
shipped to 24019
Old Apr 5, 2007 | 10:44 AM
JSC Speed's Avatar
Former Vendor
http://www.powerenterpriseusa.net/pr...bishi/Evo.html
Old Apr 5, 2007 | 12:20 PM
Vigo's Avatar
Which compressor housing comes with this kit?
Old Apr 5, 2007 | 01:08 PM
mot's Avatar
mot
3300rpm full boost is very sick
what kind of hp is this good for
Old Apr 5, 2007 | 06:25 PM
Powerman20's Avatar
Hey guys its nate from Power Enterprise. You can chose from 4 different trims and 5 different AR housings. You can choose from the tcw 15,10,76,77 and you can choose from AR's 18,20,22,25,27. Depends on what you are doing with the car. One of the only kits on the market that let you choose what is best for your application. these kits will make anywhere from 325whp to up 700whp if not more depending on your set up. Pm me if you have any questions.
Old Apr 6, 2007 | 12:12 PM
Evo_Wanted's Avatar
pm me shipped thanks,
Old Apr 7, 2007 | 05:14 PM
srt4-Joe's Avatar
pm price shipped
