FLUIDAMPR's Engine Dampers in stock- BEST PRICING!
We have these in stock and will give you a great deal on these usually backordered performance viscous engine dampers.
TTP's shopcar MR has run both the ATi and the Fluidampr on our 10 second Evo and in many ways the Fluidampr has been the winner.
1. Easy of installation.
2. Self contained, self leveling viscous matierial. Rebuild not needed.
3. Does not require a timing belt job to PRESS ON the 2 piece hub.
4. Does not require custom accessory belt to get it to fit.
5. Does not require modification of the timing cover to get it to work.
6. Does not have and inner and outer part screwed together that can break.
The fluidampr we use on our shopcar helps unsure the engine harmonics are minimized through the crankshaft and helps keep things balanced.
Fluidampr engine damper's can actually increase power while minimizing harmonics transferred through the crank twisting and flexing. Using the performance engine damper such as the Fluidampr can extend engine bearing life, especially in high horsepower applications.
Many units in stock, they will go fast.
Just off backorder, will not last. Best Pricing GUARANTEED
Pricing available via PM.
Please visit our site for other killer deals www.ttp-engineering.com/store !
Back in stock and shipping daily.
In stock!
We have 11 ALL ALUMINUM CONSTRUCTION Fluidampr's available. Once they are gone, all that will be available is the heavier steel version. Make sure you get your aluminum units before they are DISCONTINUED.
After this batch in stock. No more unit are being made in aluminum. Even the steel ones are projected 6-8 weeks out, so you will not even be able to obtain ANY Fluidampr in the near future.
Thanks TTP, ordered mine on Wed!!! great price too!!!
