AEM and Innovate Widebands
DB-Blue or red Gauge / LC-1 Kit-$249
This kit comes complete with the patented award-winning LC-1 Wideband Controller, DB-Blue Gauge, Bosch 5-wire Wideband 02 Sensor, Bung/Plug Kit, Software CD, and quick start guide.
The LC-1 is more accurate than conventional designs costing many times as much, and its self-calibrating circuitry can compensate for changes in temperature, altitude and sensor condition. The LC-1 is ideal for applications such as Dynos, Data Acquisition, Standalone ECUs, piggyback fuel controllers, OBD-II software or chip programmers, and gauges. With the LC-1, you can add additional wideband channels to your LM-1, convert an existing narrow-band gauge, or add wideband capabilities to your dyno. You can even tune individual cylinders by using multiple LC-1 kits.
Key benefits of the “DB” kits include:
The industry’s most accurate and fastest-responding wideband controller.
One additional available analog output (one connects to the gauge).
Easy set up and wiring (instructions included).
LC-1 incIudes Innovate serial in & out for adding additional modular tuning system (MTS) components. (Gauge itself is analog only- no serial).
“Blackout” appearance when unpowered.
Log directly from the LC-1’s digital output into laptop w/included software:
XD16 Standalone Gauge Kit-$339
The Innovate “Standalone Gauge Kit” comes complete with the patented award-winning LC-1 Wideband Controller, NEW! XD-16 (16 in 1) 52mm Programmable Digital Gauge, Bosch 5-wire Wideband 02 Sensor, Bung/Plug Kit, Software CD, and quick start guide.
The Innovate XD-16 dash-mountable Digital Display ships as an AFR gauge, but can also be configured to display any channel of the Modular Tuning System. Key features:
-2 Bezels + 8 faces = 16 combinations (see below)
-3/4” thick, so it's possible to mount even in surface mount configurations
-3-character LED display
-Record/Calibrate/Peak Hold button
-Programmable (values and colors) digital needle
-Billet Aluminum bezel
The kit also includes:
-Male 2.5 to 2.5 cable to connect XD-16 to an LC-1, AuxBox, LM-1, ST-12, or DL-32
-Terminator Plug
-Mounting Hardware Kit
-Cable to connect to a PC for real-time logging and programming.
LM-1 basic kit: Digital Air/Fuel Ratio Meter-$299
The Kit includes the LM-1 meter, a Bosch wide-band oxygen sensor, 10 ft sensor cable, cigarette-lighter power adapter, serial cable for PC connection, 9V battery, exhaust bung and plug, CD and quick-start guide.
Tuning an engine for maximum power previously required long trial-and-error sessions on a dynamometer. With the LM-1, precise AFR measurement allows the user to correctly adjust many variables- including carburetor jetting, fuel injection, turbo fuel curves, etc.- without long and expensive dyno sessions. The meter’s digital signal processing technology provides data on exactly how rich or lean an engine is running at any load. The LM-1’s self-calibrating circuitry also compensates for changes in temperature, altitude, and sensor condition.
The instrument can sample and store the air-fuel-ratio and the other sensor data internally in operation for later analysis on a personal computer. At a sampling rate of 12 samples/second the instrument can store up to 44 minutes worth of data in non-volatile memory. The data can be downloaded to a personal computer using a standard serial port and viewed/analyzed by the included software or any standard spreadsheet program as seen in the picture above.
LC-1 Lambda Cable (Standalone Wideband Controller) with 02 Sensor-$174
*Bosch Wideband Sensor Included*
The LC-1 is a complete wideband controller built in to a sealed cable. It features the same award-winning patented digital measurement principal found in the LM-1, and includes digital input, output, and 2 programmable analog outputs.
Key Features
Only fully digital wideband controller.
Auto calibration capability to compensate for changes in temperature, altitude, and sensor condition.
Two user programmable analog outputs.
Permanent install applications
Cost effective individual cylinder tuning.
Easy to upgrade.
Includes LogWorks software
AEM widebands-Pm for special pricing
-Terminator Plug
Key Features
Easy to upgrade.
TitanMotorsport
20
Aug 14, 2013 01:13 PM
SBR INC
Dec 23, 2009 02:33 PM
AWD Motorsports
Evo 'For Sale' Electronics / Lighting / Audio
16
Jun 27, 2008 09:59 AM
InjectedPerformance
106
Apr 4, 2006 08:46 AM
