EVO High Boost Fuel Pack - SUPER COMBO
Old Apr 14, 2008 | 01:31 PM
LancerShop.com's Avatar
Gold Sponsor
Arrow EVO High Boost Fuel Pack - SUPER COMBO
The Walbro fuel pump is an ideal upgrade for any EVO that is running more boost then stock. The in-tank fuel pump makes for a clean, easy installation by replacing the factory unit. Remember more boost always requires more fuel to be safe.
Being able to properly tune is of utmost importance for extracting peak performance from your EVO's setup.
The S-AFC NEO allows you to monitor Karman Hz (on the Evo), throttle position, correction factor, RPM, knock level, and battery voltage.
Completely new case design
- Compact design
- 16 point fuel correction
- Color FED display
- User defined button and background colors
- Inverted "anti-glare" screen
MONITOR MODE
* RPM
* Throttle
* Battery voltage
* Correction %
* Air flow %
* Pressure
* Karmann
SETTING MODE
* Air map
* Air map graph
* Throttle point
* Deceleration air
TECH TIP: This package is ideal for EVO's running higher boost then stock or EVO's with aftermarket camshafts.
Fits: Mitsubishi Lancer Evolution 7/8/9
Part # GSS-342 + 401-A917
Price includes Walbro 255lph Fuel pump + Apexi S-AFC NEO Digital Fuel Computer.
Click Here - for the lowest price EVER
Personal Shopping Assistants Available 9am-5pm EST M-F
Old Apr 17, 2008 | 11:32 AM
Gold Sponsor
Thanks for the orders with LancerShop
