201 Motorsports Power Post!!
APS Dual Vent Blow Off Valves @ 201 Motorsports
Price: $250 shipped
Originally Posted by APS
With the huge air flow capacity of the turbocharger utilized in the Lancer, the unique APS High Volume Twin Vent Blow Off Valve delivers unsurpassed venting performance, excellent driveability and crisp turbocharger response in on/off throttle applications. A blow off valve is a device that releases pressure from the turbocharger when the throttle is released. It ensures that the pressure shock load on the turbocharger compressor is minimized and encourages the turbocharger rotating group to continue spinning during gear changes. This ensures that when the next gear is selected and the throttle re-applied, the turbocharger rapidly produces high boost pressure and strong torque.
With large turbochargers, releasing pressure from the turbine compressor wheel when the throttle is snapped shut is critical not only for turbocharger response, but for turbocharger longevity. A huge volume of air must be passed through the blow off valve as soon as the throttle is closed. Most blow off valves have limitations in their design that inhibit the level of performance demanded by APS. Piston/bore diameter and venting ports are often too small and surprisingly, most will not fully expose the exhaust ports when fully opened.
APS designed the APS high volume twin vent blow off valve specifically for the Lancer in high power states of engine tune.
A mammoth 1.417" (36 mm) internal bore size delivers huge capacity and at full piston travel, all ports are fully exposed for maximum blow off volume.
The APS twin vent BOV features 30 micron hard anodized, T6 billet aluminium body, low friction bronze piston, all stainless steel hardware including spring and Viton 'O' rings.
The large primary vent is designed to plumb back into the inlet tract and ensures the best driveability during cruise conditions. More importantly, the APS BOV cures the problems seen with after market 100% external venting blow off valves. And under spirited driving conditions with the turbocharger running high boost pressure levels, the APS twin vent blow off valve continues to vent through to the second stage port in order to expel the maximum amount of charge air possible. Fine adjustment to blow off valve operation can be performed through the actuation adjustment screw for optimum configuration.
Cobb Tuning @ 201 Motorsports
Cobb Tuning Access Port
Price: $695 shipped (Free Overnight)
Cobb Tuning SF Intake
Price: $115 shipped
The AccessPORT by COBB Tuning, Inc. is a handheld programmer that allows you to unlock your vehicle's hidden potential by reprogramming the stock Engine Control Unit (ECU).
The EVO VIII can see gains of +24% hp and +20% lb-ft.
The EVO IX can see gains of +24% hp and +10% lb-ft.
With a short and guided installation process you can upgrade the ECU in your car from stock to one of our performance oriented tuning maps. The unit uses the OBD-2 diagnostic port, and requires no cutting, wiring, or other such modifications, simply plug-and-play.
The crowning function of the AccessPORT is COBB's unique 'Real-Time' mapping, which allows you to change the tuning data within seconds, as opposed to minutes. Simply park, switch realtime, and resume driving, it's literally that easy.
Using our off-the-shelf staged maps, the AccessPORT can unlock the potential of your vehicle by as much as 50hp, and more based on further modifications. The possibilities are endless since the AccessPORT is a short ProTUNE away from giving your car even more potential from the staged maps.
The COBB Tuning SF Intake utilizes our custom design to maintain optimal flow and net the ideal performance. The custom conical cloth filter feeds filtered air directly to the engine, while maintaining optimal intake velocity and minimizing turbulence found with many aftermarket intake systems. The COBB Tuning SF Intake system is compatible with Stage 1 and Stage 2 OTS (off the shelf mapping) provided for our AccessPORT ecu tuning device.
In order to provide a system that looks as good on the outside as the technical advancements happening on the inside, we utilize a one piece design constructed from a high temperature plastic composite that offers heat rejection properties that help keep intake air temperatures cooler. In contrast, intake systems constructed using metal castings or piping can actually retain underhood heat and in turn heat the incoming air.
Beatrush @ 201 Motorsports
With year of experience in motor sports, Laile; which manufactures, brands, and operates Beatrush; has collected sufficient data information on the tracks of Japan to produce high quality and functional products. Located in Yokohama, Japan; Laile manufactures most of their product's brands like Beatrush and Arpsports with their high precision machinery. All the unique products developed by Laile offers superior safety and plenty of pleasure both in track and the street, as well to look at.
Beatrush Engine Roll Stopper
Price: $160 shipped
Price: $160 shipped
Beatrush Exhaust Manifold Heat Shield
Price: $145 shipped
# Fits all Mitsubishi Evolution 8 & Mr 2003-Up.
# Light Weight, Strong, and Rigid.
# Made of forged 7075 aluminum alloy with urethane pillow ball bushing.
# 250g lighter than stock.
# Traction is greatly improved due to the significant reduction of front-to-back movements while the engine is under on/off throttle conditions; furthermore, it improves shifter feel and on/off throttle response.
# Track tested for functionality by Beatrush of Japan.
* Prevents heat expansion to the rest of the engine bay caused by extreme heat from exhaust manifold.
* Polished stainless steel piece that will enhance the look of the engine bay.
Fits all 2003-up Lancer Evolution 8 and 9 Models.
HKS RS Replacement Filters @ 201 Motorsports
All filters are $30 shipped
Limited Edition Aegean Blue
Limited Edition Sunset Orange
Purple
Yellow
Purple
Yellow
We just got a HUGE shipment of Sun Auto products in stock! We're loaded up on just about everything. Let us know what you need and then we'll get it on your doorstep! Find a lower price elsewhere? No problem!
We are an Authorized Sun Automobile dealer- that means we WILL NOT BE UNDERSOLD!
___________________________________
Hyper Force System
Hyper Force System
Originally Posted by Sun Automobile USA
Sun Hyper Force System is new high-efficiency ignition tuning and strengthening system by Sun Automobile. Hyper Force System focuses on direct ignition engines and is available in 4 and 6 cylinder versions.
A normal ignition coil inherently generates back electromotive force (back EMF) during operation. This back EMF negatively affects the ignition device inside the coil, decreases plug voltage, and negatively affects plug efficiency. With this problem, voltage not only becomes unstable but also produces ignition time lag in the next ignition cycle. HYPER FORCE SYSTEM works by absorbing all back EMF, which aids to improve plug voltage and promote complete combustion by producing 100% coil efficiency. Furthermore, HYPER FORCE SYSTEM eliminates any ignition performance loss due to decreased electrical current under heavy throttle. Since ignition efficiency over the entire rev range improves, available torque and acceleration response improves; this efficiency enhancement also contributes to better fuel efficiency and a reduction of harmful emissions.
What results? Increased Engine Response, Improved Fuel Efficiency, Increased Horse Power and Torque, Reliable ignition spark throughout the entire rev range, and Reduced emissions / stabilized idling
Price:$350 shipped (Evo-specific harness included!)
Hyper Voltage System
The H.V.S. Cyber Speed Version is designed to stabilize voltage in your vehicle for maximum battery efficiency, allowing its full potential to be released. H.V.S. Cyber Speed Version provides both function and stylish appearance; units are designed to fit perfectly for your vehicle, with specialized brackets and three additional grounding cables. The most secure and reliable mounting locations have been determined by our engineering and design team, to ensure an easy installation and excellent performance. An LED on the unit also operates as a system monitor, to alert you when your battery may need service or replacement.
Benefits:
-Increased horsepower
-Increased torque
-Better gas mileage
-Improved throttle response
-Longer battery life
-Improved battery efficiency
-Reduced emissions
Benefits:
-Increased torque
-Better gas mileage
-Reduced emissions
Price:$242 shipped
Sun Auto Ignition Blade
Introducing an all new ignition strengthening product born from the Hyper Ground System. It eliminates negative ions circulating throughout the ignition coils and cylinder head, therefore, providing the lowest possible resistance enabling the ignition system to reach maximum potential.
NOTE: When installing in conjunction with Hyper Force System, you can expect an even better result!
Price:$162 shipped
Again... Find a lower price elsewhere? No problem!
Megan Racing @ 201 Motorsports
Megan Racing Evolution 8 Catback
Price: $399 + shipping
Megan Racing Evolution 8 Downpipe
Price: $159.95 + Shipping
Megan Racing Evolution 9 Catback
Megan Racing Evolution 9 Downpipe
Price: $189 + Shipping
Megan Racing Cat-Back Systems complete your exhaust from the catalytic converter out. Made of 100% T-304 Stainless Steel for long-lasting durability, these systems feature smooth bends and a straight-through design for superior performance; while the built-in resonator and dual-chamber silencer offer a mellow yet aggressive tone for the street. To finish off your ride just right, the polished finish and clean welds offer the perfect show-quality you desire.
Spec:
* Project EVO 8 Cat back system Special Edition
* Turbo Type Series
* 4.5" Flat tip with removable double-layer silencer, 3" inlet
* 100% stainless steel with polish finish
* Producing strong, deep and noticable sound
* Gain more horse power, faster response, averaging 10-15 extra hp
* Comes with gaskets
* Warranty included
Spec:
* Turbo Type Series
* Warranty included
Megan racing performance downpipes are made to last long and increase performance. All pipes are made with 100% complete stainless steel with silver chrome finish.
Spec and Features:
* Fits from 2003-2004
* 100% SUS-304 Stainless Steel with computerized mandrel-bent
* 3" piping
* CNC machine flanges for strong solid support
* TIG weld for strength and durability
* 3 stage polish shine like a mirror
* Increase around 8-12 horse power and torque
* Straight through design and bolt-on installation
Spec and Features:
* 3" piping
One of Megan Racing s strongest products, the Cat-Back System is made of SUS-304 Stainless Steel with a fully polished surface, CNC machined flanges and mandrel bends. Its aggressive styling, and deep, strong tone are just part of the MR Cat-Back characteristics. It also serves to improve horsepower, torque and overall performance with its straight-through design. The exhaust systems have 2.5” piping and 3” piping for certain forced induction models. Finished with a tip that is designed to increase the scavenging effect and achieve maximum performance, while adding a perfect match on exterior styling as well. As a direct bolt on, each Cat-Back comes with a 12-Month warranty.
Spec:
* EVO 9 Cat back system
* Fits 05+
* Turbo Type Series
* 4.5" Flat tip with removable double-layer silencer, 3" piping
* Warranty included
Spec:
* Fits 05+
* Turbo Type Series
* Warranty included
Due to popular demand, Megan Racing has finally developed our Stainless Steel downpipe for the 05+ Mitsubishi Evolution. This true 3" pipe is a direct bolt on to stock components and allows the use of BOTH under braces without any modification to your car.
The piping is constructed of stainless still with the exception of the first 90-Degree bend which is constructed of Cast-Steel. The reason for this was to keep the bend more uniform and the CFM of the exhaust up.
