Slowboy 20g Turbo Package Upgrade!!!!!!!!
Magnus special race intake manifold with 75mm throttle body flange ON SALE, IN STOCK READY TO SHIP!!!
$725 SHIPPED!!!!!!!!!!
I can throw in a matching 75mm throttle body for $280.00 with purchase of the manifold.
PM ME NOW!!!!
Joe
jws@slowboyracing.com
PM ME NOW!!!!
Joe
Innovate Wideband
HOLY CRAP
Innovate Wideband #3795
229Shipped!!!
Don't miss this epic deal as we only have a limited quantity in stock!!! 10 to be exact; now you can monitor your vital lifeline for cheap!
<span style="font-size:large">LJ@slo...ing.com</span>
Perrin cat back exhausts on sale!!!!!!!!
SPECIAL PRICE OF $445.00 SHIPPED!!!!
PM ME NOW WHILE THE DEAL LASTS!!
Joe
Joe
Dial all your bolt on mods in properly and get the full potential out of your car with a Cobb Access Port! The AccessPORT is a handheld device that allows you to reprogram your vehicle's computer (ECU) to optimize parameters such as the air/fuel ratio and ignition timing. The "mapping" will also increase boost, remove the speed limiter, and more for instant performance results you can feel!
IN STOCK READY TO SHIP!!!!!
PM ME NOW FOR PRICING!!!!!
Joe
Joe
Do you want GT35r performance without the GT35r price?
Does being able to handle 45psi of boost and making your car sound like a mack truck get your gears turnin??
I almost forgot the most important part. This turbo is completely rebuildable, COMPLETELY!! Just keep that one in mind when you decide you're going with this unit!
Boys and girls we bring to you
S362
1230.00 plus shipping for a t3 .70ar 362!!!
Keep in mind this turbo can yield almost the same results as some other high cost 35r's and has almost the same type of spool. Average on a 2.0 is usually before 4500rpm!!!!
LJ@slowboyracing.com
Ross/ Oliver Combo
Stock engines are fun
Blown up stock engines from making too much power aren't
!Don't miss out on fun and have downtime in your broke ride when you can swap in these
1365 shipped!!!!!
1365 shipped!!!!!
Cosworth EVO IX 272 camshaft sets in stock!!
$620.00 SHIPPED!!!
We have 2 sets on the shelf, get them before they run out!
Joe
$620.00 SHIPPED!!!
Joe
THATS NOT ALL! I also have Manley pistons available at decent discounts!
Round wire locks, tool steel wrist pins, and rings are included with every set at no additional charge.
Forgings
- 2618 alloy for maximum high temperature strength and fatigue resistance.
Attributes
- "Contour forgings" provide the optimum balance between strength and weight with no grain-interrupting internal milling.
- Proprietary multi-step top ring groove machining process assures optimum control of the groove's size, geometry, flatness and finish.
- All final turning is performed in one fixturing resulting in complete squareness of rings to the cylinder wall.
- Federal Form-Scan gauging validates ideal skirt indexing to pinhole and skirt-to-skirt polarity.
- Value - added features such as a pressure balance groove included in all series.
- Precise pinhole machining results in an exact compression distance as well as precise lock ring groove spacing, size and concentricity.
- All Manley pistons come with a hi-temp moly skirt coating
PM me or BEST AVAILABLE PRICING on all 4 cylinder Manley piston sets!
Forgings
Attributes
How much would the 20g turbo + the install kit be shipped to Colorado? Is it just the IX turbo with the 20g compressor? What's the rated HP? Also, I'd like a price on the spark plug cover. Thanks!!!
