AEM Meth Kit in stock!!
Old Aug 31, 2009 | 02:31 PM
SBR Inc2's Avatar
WHY YOU WANT ONE
AEM’s Water / Methanol Injection Kit reduces air inlet temperatures and exhaust-gas temperatures, which allows you to increase boost pressure and advance timing without having to run higher-octane fuel. It’s like getting to run 100+ octane gas for the price of Premium!
WHY YOU WANT OURS
AEM’s Water / Methanol Injection Kit includes all the features necessary to do water/methanol injection right. No hidden costs or optional components are required. Unlike other popular kits on the market, we include a one- or five-gallon tank with a fluid level sensor standard. Also, because we think engine protection is a requirement, not an option, we include our Boost Safe output in every controller we design. This feature allows you to retard timing or reduce boost via a ground output if the system runs out of fluid or detects an error. With the AEM Water / Methanol Injection Kit, you get all the best features in one low priced kit.
HOW IT WORKS
Once installed, the Water / Methanol Injection Kit uses a boost-dependent, variable-flow progressive controller to determine the amount of water / methanol mixture (up to 50%) to feed into the inlet stream from the included one- or five-gallon reservoir. The controller commands a progressive recirculation-style 150-PSI pump that delivers the mixture, and flow adjustments at the inlet are made via three included jets designed to match most engine power requirements. The result is significant horsepower gains using pump gas—at about half the cost of Racing Fuel.
RECIRCULATION-STYLE PUMP
AEM's recirculation-style pump offers improved performance, reliability and a much smoother, quieter operation when compared to older switched-style pumps. With the use of a new internal bypass design, AEM's upgraded pump eliminates the erratic on and off switching/pulsing and ensures consistent fluid delivery for optimum performance. With durability and reliability in mind, AEM has designed the pump with a Santoprene diaphragm and EPDM seals to withstand the harshest of alcohol mixes.
OTHER COOL STUFF
You don’t have to worry whether AEM has your application because the Water / Methanol Injection Kit is designed to be universal for practically any vehicle. It includes everything you need to adapt it to your steed. Critical safety features are integrated into the system to virtually eliminate any chance of failure, including an integral fluid level sensor in the reservoir, a dash light to warn of low fluid level or error codes (including short circuits, battery voltage and more), and an additional output to either decrease ignition timing or boost if the system detects low fluid levels or a system error.
TERMINOLOGY EXPLAINED
By now you’ve most likely heard various terms in reference to water/methanol injection systems. Some refer to these systems as just water injection, methanol injection, and/or meth injection for short. In addition to those terms, these systems are often referred to as alcohol injection or water/alcohol injection. The bottom line is all of these terms are used to reference the same type of system.
What some may or may not know is that methanol is known as methyl alcohol. Methanol’s scientific name is where the “alcohol” variant name has come from. Essentially, alcohol and methanol is the same thing, however there are different types of alcohol.
*Progressive Controller with Intelligent Fault Detection
*150 PSA Shurflow Pump
*Anti-Siphon check valve come in the kit standard
*Preinstalled Fluid Level Sensor
*.155, .315 and .630 jet sizes included for a wide range of power requirements
*20 ft of hose included so you can even mount the tank in the rear of your vehicle
*Other comparable systems go for $500 to $700
Part #: 30-3000
$395.99
