Cam gears for only 220.00!! Blow Out!
Are you still deciding on which parts to buy for your car based on the vendors profit margin??
Dont make that mistake.
Heres the best cam gears for your hard earned dollars.
The New Fidanza Cam gears.
12 degrees of adjustment in each direction
Check This out
220.00 shipped for a pair. Add a PE timing belt for 149.99 and protect that valvetrain.
Check This out
Originally posted by RockVr4
Rice
Rice It is on the engine bay, it is just like an air filter kit. Blue, red or yellow etc.
Anyways, those do work with both stock or hks camshafts right?
Theoretically there should be no difference between cam gears right? They should do the same change, which is shifting the powerband. Is any one brand better than another? This isn't like an exhaust where the design can make a huge difference, right?
