Random Tech True High flow cats!!
The number one name in high flow cats is here in Bolt-on mode for your EVO.
Random Technology uses only the best materials to produce their catalytic converters. Full stainless steel construction full stainless catalyst inside allowing for the highest flow while still being function.This is what high flow cats are made to do...Be efficient and flow better than stock.This cat Flows 598CFM's!!
Dont fall for the "alleged" High flow cats that use the same ceramic catalyst as the stock unit.These are not high flow cats, they are just less expensive universal replacements....
The Random Tech is designed to fit with ANY exhaust and is available in 2.5 and 3" configurations...Pic is of one using a stock downpipe and TXS 3" cat-back...Enjoy
Only 249.99
Only 249.99
