Helix Oil Catch Can $75 shipped!
Hi all,
We just recieved a new shipment of Helix Oil catch cans! These are priced at $75 each shipped to your door! CA residents please add sales tax. Local pick up is welcome.
Helix Catch Can
The Helix Catch Can is designed to trap oil moisture and blow-by caused by normal engine operation, especially in turbo charged vehicles. On your factory vehicle, because of emissions regulations, the waste oil and sludge is generally re-routed back into the intake stream. This debris will tend to accumulate inside the intake tract, intercooler, turbocharger, as well as be ingested into the engine during normal combusion process. Needless to say, this sludge and blow-by will hurt the performance of your vehicle. The Helix Catch Can eliminates this problem by trapping such debris and insuring optimal horsepower and longevity of you vehicle.
Features: Machined and polished aluminum tank, Clear braided hoses with hose clamps and adapter, visual debris level indicator, mounts vertically or horizontally.
Please give us a call to order!
Thanks,
Cal
gruppe-s
510-498-8400
Helix Catch Can
Thanks,
Cal
gruppe-s
510-498-8400
Originally posted by SRT-4_Destroyer
Will this work with the STI, SRT-4, and the EVO?
If so, I may get a few.
Also, is there anything inside the catch can the captures the debris and keeps it from reentering the outgoing tube?
Hope this helps,
Thanks
Cal
gruppe-s
Originally posted by joseph d gordon
Great looking !! Any idea on how long it took to install? What type of absorbent compoud in put in the can?
The absorbent compound can probably be bought at local hardware store. I am not exactly sure the exact term of the compound, but its must be some sort of absorbent that won't cause the oil to leak back out.
Thanks
Cal
gruppe-s
510-498-8400
guys, an absorbing agent is not needed. It would actually be a bit of a risk for put anything in the can if your going to run it back to the intake.
You could also just run the catch can as a breather and just cap off the intake pipe instead of rerouting the can to the intake. This would serve your pupose perfectly.
Another pic of mine
Jeff
Another pic of mine
Jeff
