B&M Short Shifter deal
The B&M short shifter for the EVO8 provides a quicker shifter ratio on your transmission. This allows you to keep RPM's and your turbo spooled higher because of reduced shift time. This is a must for track racers and people looking for the extra edge.
11 in stock-
SHIPPED PRICE (cont USA) $143.00
This is the non-adjustable kit correct? If so, could you tell me the advantages of having an adjustable shifter. Also, have you heard of anyone having troubles with the 1st to 2nd gear shift and grinding (with stock or aftermarket shifter kits)?
I have trouble with 1st right from reverse sometimes... SS helped make shifts smoother
Originally posted by EVO8.com
this is a non adjustable shifter.. adjustable can lead to problems down the road (loose and not sitting still etc)
Not only is it adjustable - it's counterweighted, and comes with new bushings.... it even has a fix for boots that sag.
...but to each their own.
BTW - Isn't the one you're selling the same Part # as the Non-Evo Lancer and New Style Eclipse (00+) as well? It sure looks the same.
Originally posted by jerastan
any aftermarket knobs fit on this one?
thanks,
jeremy
thanks,
jeremy
Also on the adjustable issue I thought they meant another brand whom i will not say here
B&M's parts are great all around.The EVO8 shifter happens to be the same on the 3G not the other way around. Thanks for the input
