AEM EMS and AEM gauges---all in stock at Boost Solutions...
THIS IS THE BEST STANDALONE ECU FOR YOUR EVO8!!!
CLICK HERE FOR DETAILED DESCRIPTION OF THE AEM FUNCTIONS, WITH SCREENSHOTS!!!
AEM’s Plug & Play Engine Management System (EMS) will forever change the way you look at and perform fuel injection tuning! This user-programmable system plugs directly into a vehicle’s factory ECU harness and requires no additional wiring or hardware.* Windows™-based software (2000, NT, 98, 95, ME) makes the task of copying, viewing and manipulating data as simple as a click of the mouse. User-defined templates are easily configurable and enable tuners to establish “quick keys” to any pertinent information during the tuning process.The AEM EMS’s infinitely adjustable software allows tuners to program virtually any combination of engine control, power adders and auxiliary devices, and accurately deliver proper amounts of fuel and correct ignition timing for ANY boost level or operating condition.
Installs in Minutes (comes already preloaded with the EVo8 map)
Plug & Play Technology - No Wiring Necessary
Uses all the Factory Sensors
Fuel Table Automapping
Base Maps Included ( both for MAF and MAP equipped cars)
Programmable Traction Control
Onboard 512kb Datalogger
10 Cyl Sequential Fuel Injection
16 General Purpose Outputs
7 Definable Switch Inputs
Electronic Boost Control ( just add a $50 boost control solenoid, no need for a $500 EBC)
Soft Cut Rev Limiters
2 Step Launch Control
Wet or Dry Nitrous Control
Definable Knock Control
Full Idle Control
4 EGT Inputs w/Fuel Control
16/32 Hybrid High-Speed Processor.
Check the prodided link for more graphs http://www.boost-solutions.com/evoECUs.htm
For more Evo products for your Evo visit us on the website at www.boost-solutions.com
AEM EMS Evo8 ECU - $1650
AEM EMS Evo8 ECU with integrated Wideband O2 controller- $2199
- same as the above unit, just with added wideband O2 internal controller
AEM Single Channel Gauge Wideband O2 controller-$499
- 24 Color-coded LED display lights provide immediate reference to engine’s air/fuel ratio (AFR) or Lambda
- Integrated three-digit display reveals AFR or Lambda in real time
- Accurate to 0.1 AFR (Bosch UEGO conditioning)
- Bosch sensor included
- 0-5v calibrated output with 0-1v secondary output to eliminate trouble codes
Boost Solutions Inc.
If you have any questions or inquiries, Give us a call at 770-904-2644 or e-mail us at sales@boostsolutionsinc.net
- meet or beat competitors prices is our goal
- excellent customer service is our primary goal
- reliable before-sale and after-sale technical support is a plus
Full Idle Control
