Go Fast Bits Stealth fx EVO Bovs In The Building
The install was pretty easy, however 2 questions
1. my radiator hose is basically sitting right on top of the DV. Everything seems to work okay, just seems like it may be a problem.
2. anyone shorten up the vacuum line for better response?
leonard, you could relocate the valve closer to the i/c piping and farther away from the intake tube like I have, I initially did this due to how large the forge diverter valve is then I just left the configuration the same when I installed my MR valve.
