Electronics
Old Aug 18, 2004 | 11:46 AM
Vivid Racing's Avatar
Electronics
Available and in stock
Blitz DTT DC II
The BLITZ® DTT (Dual Turbo Timer) DCll is a one of a kind item. This is the only turbo tiimer in the world that incorporates a turbo timer with a boost gauge. The digital boost display can read up to 2.5hkpa (36.75psi) and also includes a digital boost peak hold. This unit also features the two-piece design that allows the user to virtually mount the turbo timer anywhere in the vehicle. The DTT DC ll is available in black and silver.
$127.99
Blitz FATT DC III
The FATT (Full Auto Turbo Timer) DC Ill features a unique two-piece design. The compact face design allows the face unit to be virtually mounted anywhere in the vehicle. The FATT DC lIl is available in black and silver. DISPLAY FUNCTION
FEATURES
Manual Timer ¡V Allows the user to preset count down time.
Automatic Timer ¡V The FATT DC III has the ability to calculate the count down time by the how the vehicle was driven. There are 5 different types
A-L ¡V will start to calculate time automatically after 1800rpm. Low setting
A-S ¡V will start to calculate time automatically after 1200rpm. Medium setting
A-H ¡V will start to calculate time automatically after 900rpm. High setting
E-L ¡V will start to calculate time according to how long the ignition has been on. Adds 55 seconds per hour.
E-H ¡V will start to calculate time according to how long the ignition has been on. Adds130 seconds per hour.
Voltage Display ¡V The FATT DC III has a built in voltage display. This allows the user to monitor the vehicle's charging system.
Temperature Display ¡V The FATT DC III also has a built in air temperature display. This allows the user to monitor the cabin temperature.
Stop Watch and Lap Timer ¡V This unique feature allows the user to use the stop watch function and also can record up to 5 lap times.
Adjustable Display ¡V This turbo timer can also allow the user to adjust how the bar display moves. There are 4 different display types, one moves according to throttle and the others are programmed movements.
Adjustable Contrast ¡V Allows the user to adjust the contrast setting.
$99.99
HKS TT Harness (%100 compatible with Blitz TT)
$19.99
Blitz TT Harness
$24.99
HKS Type 0 Turbo Timer
HKS’ all new Turbo Timer Type-0 and Type-1 carry over many of the popular features from the previous HKS units, including multiple preset times, audible alarms, up and down control buttons, power and memory buttons, and an easy to read back-lit digital display. Additionally, both new models feature a more compact polyurethane casing, back-lit button controls, a larger dual color LCD panel, a volt monitor function to monitor battery power, and an auto mode feature that adjusts engine idle time according to the most recent driving pattern.
$99.99
HKS Type 1 Turbo Timer
Turbo Timer Type-1 includes all of the Type-0 features, PLUS several measurement tools including a speed warning display, a two-stage engine RPM warning display, 0-400 meter acceleration time measurement and stopwatch features for lap timing.
$132.99
ApexI AVC-R Boost Controller
Advanced electronic boost controller
Highly flexible boost control with revolutionary new functions; Vacuum Fluorescent Display (VFD).
The Super AVC-R is the premium closed-loop electronic boost controller on the market. The AVC-R allows flexible control over virtually every aspect of boost control and adds new innovative functions such as injector pulse monitoring and gear specific boost control. Some key functions include: RPM-based boost and solenoid duty cycle control, scramble boost, self learning mode, 2D ghost map trace mode, analog display mode, real time replay and peak hold data modes. The AVC-R utilizes an ultra-fast microprocessor and a high quality solenoid valve to control boost. The result is ultra-fast response and accurate, stable boost control.
$493.99
Blitz SBC ID Boost Control
The SBC i-D (Sequential Boost Controller i-D) is the latest boost controller offer by BLITZ®. this unique boost controller represents the cutting edge in boost controller technology. The SBC i-D features the same dual solenoid design as the DSBC for maximum boost response and the capability to hold up to 36.75psi (2.5 bar). The SBC i-D is 1/2 din size and it is compatible with internal actuators and external wastegates.
FEATURES
Boost Unit ¡V Boost can be displayed in standard and metric measurements (PSI, bar, kPa, and kg/cm2)
Four Channels ¡V Has 4 different programmable boost settings.
Boost Gauge ¡V The SBC i-D can display boost in digital and graphical form.
Peak Hold ¡V SBC i-D can record the highest boost achieved by the vehicle.
Boost Warning and Limiter ¡V This is a safety function that allows the operator to set the amount of boost decrease in the event of over boost. Warning is in both visual and audible.
Manual or Automatic boost setting ¡V The SBC i-D allows the user the choose how the boost is set.
Manual ¡V Sets boost in ratio, from 0-100. By using the manual setting, this allows the boost controller to give maximum boost response.
Automatic ¡V Sets boost directly, just dial in desired boost amount.
Record and Replay ¡V SBC i-D has the ability to record and replay any information up to 99 seconds. The SBC i-D can also record and replay information on the Power Meter i-D and Optional Data (Power Meter i-D and SBC Optional Harness required). Replay can be fast forwarded and replayed in 2x and 5x.
Display ¡V The SBC i-D can display up to 6 different vehicle reading. Each reading can be display in both digital and graph form. SBC i-D has the option to display 5 other vehicle reading (Power Meter i-D and SBC Optional Harness required). With Power Meter i-D, the SBC i-D can display SPEED and POWER. With SBC Optional Harness, the SBC i-D can display 3 different electronic outputs from the ECU.
Boost ¡V Digital and Graph Form
OPT1/SPEED ¡V (Power Meter i-D required to display speed) ¡V Digital and Graphic form.
OPT2/POWER - (Power Meter i-D required to display power) - Digital and Graphic form.
DATA 1 ¡V (SBC Optional Harness required) - Digital and Graphic form.
DATA 2¡V (SBC Optional Harness required) - Digital and Graphic form.
DATA 3 ¡V (SBC Optional Harness required) - Digital and Graphic form.
DATA 1-3 Display ¡V This boost controller has the ability to display any electronic output from the vehicle ECU (SBC Optional Harness required). It can display almost any voltage output from the computer (i.e.: TPS, temperature, pressure, A/F, injector pulse and etc.). DATA 1-3 readings can also be recorded and replayed.
Speed Map ¡V This unique feature allows the SBC i-D to control boost according to the speed of the vehicle (Power Meter i-D required). Speed Map boost control can be set up from a 2 stage to a 4 stage control, which allows the user to set boost according to his driving style. Speed in transfer by infrared between the Power Meter ¡ViD and SBC i-D.
$474.99
Greddy Profec B II Boost Controller
GReddy'sProfec B2 is the newest release of their electronic unit. This can be used on any car that is Turbocharged. The Profec B2 measures 1"x3.5" and mounts in the car and remotely operates a solenoid connected to the Wastegate. There is a Hi-Boost feature that can be activated in less than a 10th of a second with a remote steering wheel switch. This is very convenient for racing situations! The Profec B2 features a user programmable boost curve to help maintain smooth acceleration all the way up to redline. Installation varies from 1-3 Hours.
Parts Included with GReddy Profec B Spec 2
Compact Boost Display / Control Unit
Electronically Activated Solenoid
Electrical Wiring
Vacuum Line
Mounting Hardware
Installation Instructions
Availble in Black or Silver
$369.99
Power Enterprise Boost Control Gauge 60mm
The best selling boost controller in Japan. Digitally communicate and analogically displayed for accuracy and easy to see. All-in-one wiring system makes for easy installation
Functions: Warning & Peak hold LED. High response boost controller.
Reading: -1.0kgcm2 to 2.0kgcm2 Analog display Night Illumination.
Color: Available in Black & White face.
$399.99
Misc.
Lineage Grounding Kits $94.99
Auto Enginuity Scan Tool (pc, palm, pocket pc) $217.99
Apexi Power FC $1399.99
TurboXS Utec $994.99
prices do not include shipping.
questions? PM me or give me a call at 480-966-3040 ext 226.
special ends 25 August 2004
jacky
dolson222
46
Feb 19, 2015 01:52 PM
Eugene@SPE
Jan 16, 2009 11:47 AM
Gruppe-S
Jan 14, 2008 02:20 PM
Evasive EVO
Evo 'For Sale' Exterior Styling
62
Jul 31, 2007 01:15 PM
