Agency Power Fuel Rail w/fuel pump
Agency Power Fuel Rail and Walbro 255 Fuel Pump
$259.99 Free shipping
This fuel rail is a direct replacement for the factory unit. The CNC machined piece is anodized in Agency Power Gold. It fits with the stock fuel pressure regulator and fittings and can be set up to work with aftermarket units as well. The fuel rail also has a location to put an aftermarket fuel pressure gauge with no modification.
Why is this Agency Power Fuel Rail better then stock? Well, the AP fuel rail has a wider diameter for fuel flow then stock. As well, the AP rail is designed to fit larger injectors such as Blitz, RC, and other common brands. When upgrading to a larger turbo set up or needing to upgrade your fuel system, the AP rail will accommodate your needs. While keeping stock fitment and performance when additional fuel is not needed, the fuel rail is also a great dress up piece.
Walbro Fuel Pumps are direct replacements and all wiring is a plug in. They flow 255L/HR which is much larger then your stock. The pump is good for up to 400 horsepower. Walbro is pictured on the right...Stock is on the left.
