Zeal V6 Coilover In stock ready to Ship, ALSO XS
Originally Posted by CharlieGsanD
just FYI ......tried to install a pair of these functionX's on a friends car last week & in closer examination it seems the front struts have had the alignment poisition for the Hub carrier mount bolts moved so as to give the car more camber. unfortunatly this did not work with the stock evo 9 wheels as the offset put the tire right on top of the spring. & attempting to dial out camber W the Camber plates moves the whole strut assembly so no clearance can be gained there
in talking to endless/zeal my friend found out that these coilovers were designed for an aftermarket/JDM wheel & some wheel spacers will be needed to get the OEM 9 rims to fit & possibly an eccectric or two to get the camber to an acceptable range for daily driving
i did not purchase them. i was just doing the install for a friend.
but, on the invoice i saw it said Function X & the Springs had "X-Coil" written on them & he called them function X's, so im assuming there the Function Xs
From what i gather the Function X's were custom setup to your/500whp spec. if your also selling another more agressive setup (Super Function R)perhaps the settings/camber specs got swapped by the manufacturer or perhaps you shipped my friend a set of Function R's by mistake?
Originally Posted by 500whp.com
Please contact your Endless dealer or Endless USA because all the function x and xs should be bolt on products w/ out any mods to install them. Yes the super function R is super aggreesive comes w/ a lot of camber.
ill post some pics when we do the re-install, that should help clarify the issue a bit more
he purchased them from you.
DrivelineSales
EvoX 'For Sale' Suspension / Brakes / Handling
67
Dec 15, 2008 11:55 AM
Speed Element
Evo 'For Sale' Suspension / Brakes / Handling
Dec 2, 2006 03:55 PM
500whp.com
Jul 18, 2006 10:47 AM
500whp.com
Jun 5, 2006 11:10 AM
500whp.com
35
May 25, 2005 10:40 AM
