CUSCO Full Suspension works!
Hello All!!!
Spring time is in the air and the track days and summer driving are right around the corner. If you are looking for suspension to get your car at just the right height and the suspension dialed just right. check out the following items from CUSCO.
Let's start out with some basics!
CUSCO STRUT TOWERS!
Strut towers will help you stiffen your chassis and give you a better handling feel.
Check out the CUSCO Video HERE!!!
Cusco Front Strut Bar -
VR web - $156.99
EVOM Member - PM for Special pricing
**CARBON ALSO AVAILABLE***
Cusco Rear Strut Bar -
VR web - $156.99
VR web triangle bar - $127.99
now for the fun part, the coilover systems!!!
CUSCO COILOVERS!
To learn more about coilovers check out the cusco movie HERE!!!
Cusco ZERO 2R
The design that is seen in most JGTC and WRC competition vehicles is now offered through Cusco top of the line Zero-2R suspension kit. Featuring all the standard characteristics oc the Zero-Series lineup, the 2R offer the inverted shock piston design. Available for McPhearson strut style suspensions; the over sized shock piston is ideal to add rigidity to the suspension. Cusco patented oil circulation method offers extremely low friction surface inside the shock while retaining excellent ride quality. With the 5-way adjustable shocks, the suspension can be fine tuned for any driving condition. The kit includes upper perch, dust cover, bump stop, shock, spring, and spanner wrenches. Installation is straightforward and bolts on using normal hand tools.
VR web - $2,219.99
Cusco ZERO2
The Zero-2 suspension kit shares all the same components as the Zero-1 kit, but adds 5 levels of dampening. For the more performance oriented consumer, the adjustable dampening allows greater tuning of the suspension. The kit includes upper perch, dust cover, bump stop, shock, spring, and spanner wrenches. Installation is straightforward and bolts on using normal hand tools.
VR web - $1,940.99
Cusco ZERO1
The Zero-1 suspension kit is the first level in the Zero-Series lineup. This kit is ideal for the enthusiast that wants excellent performance without breaking the bank. Offering all the features of the Zero-Series, the kit includes upper perch, dust cover, bump stop, shock, spring, and spanner wrenches. Even though this kit does not offer adjustable dampening, upgrading to the adjustable Zero-2 shock at a later date is available. Installation is straightforward and bolts on using normal hand tools.
VR web - $1,589.99
Cusco Zero2E Coilovers (norm. mount) Mitsubishi EVO CT9A VIII/IX
Cusco Zero2E Coilovers (normal mount) Mitsubishi EVO CT9A VIII/IX
Cusco heard your request, and have now answered with the all new Zero-2E system. With all the same benefits and features as the Zero-2 coilover, the Zero-2E adds the option to electronically control the shock adjustment from inside the car. Utilizing the E-Con (sold separately P/N: 00B 60M 0), you can select what stage (of 5) you want the shock set at. With great features such as:
- Electronically controlled shock adjustment (w/ E-Con)
- Normal upper mounts
- Adjustable shock casing
- Independent adjustable spring perch
- Stainless steel thread body
- Stainless steel case lock nut
- Stainless steel spring perch/lock nut
- Specially coated lower bracket
Fits perfectly for any style driving. The advanced design features 5-stages of shock adjustment that exhibits incredible performance! Create a comfortable ride for your passengers. Too stiff? Comfort is just a button away. No more frustrated passengers! Endures through the hardest drives!
Height adjustment and spring pre-load are designed to be adjusted independently. Lower your car with the adjustable shock casing while retaining the overall shock stroke. Set the spring pre-load to your desire and feel the difference in driving and traction.
Cusco developed a new shock absorber for the Zero-2E that further reduces friction resistance of the dampening force to achieve high performance with the vehicle lowered.
- New design: Side port rotary valve
- New: Reduced friction piston
- New oil reducing cavitation
- New material: Special steel for piston valve shim
Worried about rust? No problem with the Zero-2E stainless steel lock nuts, lower seat, and threads. With the external cylinder and threads being stainless steel, adjusting the height will be smooth. The lower bracket/case has a new special coating as well. The internal as well as the external surface has been coated.
*be sure to always clean the threads prior to adjusting the height. Road debris and brake dust can settle on the threads causing difficulty in smooth adjustment.
VR web - $1,841.99
Cusco Zero2E Coilovers Mitsubishi EVO CT9A VIII/IX
- Pillowball upper mounts
Fits perfectly for any style driving. The advanced design features 5-stages of shock adjustment that exhibits incredible performance! Create a comfortable ride for your passengers. Too stiff? Comfort is just a button away. No more frustrated passengers! Larger size pillowball used in the upper mounts. Endures through the hardest drives!
VR web - $1,940.99
Cusco Zero2E E-Con Controller
- 6 preset memories available
- Only a push of a button needed to fit any style
5 stage adjustment for the front and rear independently. Each shock is designed specifically for the vehicle application. (one by one adjustment operation)
With the operation panel thickness being a mere 30mm, installation and location options are increased. The compact control unit can easily be hidden away and out of sight.
Dimensions: W x D x H
Operation Panel: 100mm x 30mm x 30mm
Control Unit: 125mm x 82mm x 30mm
The E-Con uses high quality adjustment motors to control the rebound force quickly and accurately. The motor utilizes a special rubber cover to shield itself from moisture caused from the extreme humidity and temperatures found in the engine bay. Installation is a cinch with the specially designed bracket on the Zero-2E coilovers.
*Note: Please do not adjust E-Con while driving
Brightness of the operation panel can be adjusted. (also can be turned off). Confirmation sounds can be turned on or off. Will fit with Cusco strut bars.
The E-Con kit includes:
Rebound force controller x1
Operation panel w/ wire harness set x1
Main power wire/adjustment motor x4
Wire for motor 5m x2, 4m x2
VR web - $419.99
Feel Free to contact me with any questions you may have or if you like to place an order!!!!!
Thanks for looking
Jon
CUSCO STRUT TOWERS!
VR web - $156.99
VR web - $156.99
CUSCO COILOVERS!
Cusco ZERO 2R
VR web - $2,219.99
Cusco ZERO2
VR web - $1,940.99
Cusco ZERO1
VR web - $1,589.99
VR web - $1,841.99
VR web - $1,940.99
VR web - $419.99
Thanks for looking
Jon
Spun Autosports
Evo 'For Sale' Suspension / Brakes / Handling
53
Nov 29, 2008 04:27 AM
Vivid Racing
Jul 27, 2007 10:04 AM
Gruppe-S
44
Feb 28, 2007 02:08 PM
Gruppe-S
17
Nov 30, 2006 06:06 PM
