Evo 'For Sale' Suspension / Brakes / Handling Includes pads, rotors, springs, shocks, swaybars, and other handling related components.
test
Old Mar 26, 2008 | 07:25 PM
VelocitySource's Avatar
test
Tein S.Tech Springs Mitsubishi EVO VII VIII IX 01-07 $210 SHIPPED
Model: SKR84-AUB00
http://www.velocitysource.com/catalo...oducts_id=4570
TEIN S.Tech Springs are an excellent step towards suspension tuning. They offer approximately a 1.5 inch drop for a more aggressive appearance and increased road holding capability. Designed to be used with OEM or OEM replacement shocks. Each application is road tested in North America for the proper balance between performance and comfort. Comes with a 1 year limited warranty, spring length is guaranteed not to sag more than 5mm, and be clear of any manufacturer defects.
Additional Features:
- Chrome Vanadium SAE9254V Construction
- Progressive Spring Rate Design
- Includes Silencer Rubber on certain applications
- Green Powder Coat Finish
- Developed to be used in conjunction with OEM or OEM replacement dampers
- 1-year Manufacturers Defect and Sag Warranty (Covers over 5mm sag, breakage, deformity, and noise. Does not cover powder coat finish and rusting.)
Contents of Spring Kit:
- Individual Springs x 4
- Main Spring x 4
- Some applications include TEIN Silencer Rubbers
- Warranty Information and Bump Stop Reference Guide
- 2 TEIN Decals
Ride Height:
Front: -2.01"
Rear: -0.87"
Spring Rate:
Front: 210 lbs/in
Rear: 290 lbs/in
Tein S.Tech Springs Mitsubishi EVO VIII IX MR 05-07 $200 SHIPPED
Model: SKR94-AUB00
http://www.velocitysource.com/catalo...ducts_id=20814
- Main Spring x 4
- 2 TEIN Decals
Ride Height:
Front: -1.77"
Rear: -0.79"
Spring Rate:
Front: 210 lbs/in
Rear: 290 lbs/in
Eibach ProKit Springs Mitsubishi EVO VIII/IX 03-07 $230 SHIPPED
Model: 6041.140
http://www.velocitysource.com/catalo...roducts_id=973
The Pro-Kit is Eibach's premium suspension product and is considered to be one of the world's top performance suspension products. The performance and reliability has been proven in millions of Pro-Kit spring sets sold in all five continents and in over more than 40 countries around the world.
The Eibach Pro-Kit spring system is the first choice for enthusiasts when upgrading their vehicle's suspension, improving both the vehicle's performance and appearance. The Pro-Kit provides, quite simply... "The Look That Performs".
High ground clearance and huge fender-well gap inherent from the factory give your vehicle an unfinished look. Whether you plan to stay with your factory tires and wheels or adding performance wheels and tires, chances are, your car has "the lifted look". In reality a "Plus 1" or "Plus 2" wheel and tire package with a lower profile tire will exaggerate the large gap even more.
An Eibach Pro-Kit is designed to reduce the fender-well gap by safely lowering your vehicle, giving it a more attractive, sportier stance. The Pro-Kit is the perfect compliment to any vehicle, whether in stock form or fitted with a larger tire and wheel package. The Pro-Kit will set your vehicle off from others, giving it "The Look" you want.
The Eibach springs drop your EVOVIII 1inch in the front and rear.
Brembo Front 14" 4pot Brake Kit 2pc Mitsubishi EVO VI-IX 99+
$3,020 SHIPPED
Model: 1B1.8038A
http://www.velocitysource.com/catalo...ducts_id=34318
This line is dedicated to the most demanding customers.This braking system originates from the Racing components, consisting of a ventilated, integral or composite disc, available drilled or slotted, aluminium calipers, a complete set of high performance brake pads, metal braid tubes and high quality small parts.
4 Piston
355x32 2-piece
Caliper Color: Black, Silver, and Red. Please select below.
Rotors: Drilled or Slotted.
Brembo Front 14" 6pot Brake Kit 2pc Mitsubishi EVO VI-IX 99+
$3,280 SHIPPED
Model: 1M1.8025A
http://www.velocitysource.com/catalo...ducts_id=34319
6 Piston
355x32 2-piece
Caliper Color: Black, Silver, Yellow, and Red.
Brembo Rear 12.9" 4pot Brake Kit 2pc Mitsubishi EVO VI-IX 99+
$2,680 SHIPPED
Model: 2C1.6007A
http://www.velocitysource.com/catalo...ducts_id=34320
4 Piston
328x28 2-piece
MOUNTS PM for EvoM Pricing
STRUT BARS PM for EvoM Pricing
SWAY BAR LINKS PM for EvoM Pricing
SWAY BARS PM for EvoM Pricing
UNDER BODY PARTS PM for EvoM Pricing
BRAKE PARTS PM for EvoM Pricing
***ALL EVO PARTS***
