Evo 'For Sale' Suspension / Brakes / Handling Includes pads, rotors, springs, shocks, swaybars, and other handling related components.
NEW RELEASE!!! Torque Solution Evo 5-9 Engine Mount Inserts!!!
Old Nov 20, 2012 | 11:39 AM
  #76
Shaun@AWDMotorsports's Avatar
ttt
Old Nov 27, 2012 | 11:50 AM
  #77
Old Nov 29, 2012 | 12:16 PM
  #78
johnnnyjeans's Avatar
ordered 2pair for both cam/trans bushings.
got free shipping.
keep up the good work guys.
Old Nov 30, 2012 | 08:00 AM
  #79
do you guys have the rear motor bushing?
Old Nov 30, 2012 | 02:21 PM
  #80
No just the 2 rears and the front...
Old Dec 6, 2012 | 11:45 AM
  #81
ttt
Old Dec 13, 2012 | 02:25 PM
  #82
bump
Old Dec 19, 2012 | 08:25 AM
  #83
ttt
Old Dec 26, 2012 | 02:59 PM
  #84
bump
Old Dec 31, 2012 | 01:04 AM
  #85
Front mount: torque solution SOLID.
Cam/Trans mount: torque solution POLYURETHANE.
I first installed the front SOLID torque solution motor mount. This reduced engine roll a lot with a decent amt of vibration. Way better now that it is settled in. 500miles broken in.
THEN...
I installed torque solution POLYURETHANE cam & trans side motor mount INSERTS. Only on the car for 20miles.
I heard that installing side mounts are suppose to reduce the vibration of the car (only if they are all solids? or only if they are all polyurethane?)
I am getting HORRIBLE vibrations now to a point where i can't even stand it.
Did i mismatch the mounts incorrectly? (solid & polyurethane).
help please.
the mount polyurethane inserts for cam/ trans have only been in for 20 miles. how many miles should i wait to see if they settle down at all?
should i just replace the cam ones to stock and see how that helps? and leave the trans one alone with the polyurethane?
Old Jan 3, 2013 | 12:17 PM
  #86
AWD Motorsports's Avatar
THEN...
help please.
Torque solution doesnt make any solid mounts.. they are all 75a urethane.. The one that causes the most vibration is the rear mount.. if you dont have that and its vibrating more than you like then you would want stock mounts back in the car..
Old Jan 8, 2013 | 11:23 AM
  #87
ttt
Old Jan 10, 2013 | 09:52 AM
  #88
bump
Old Jan 15, 2013 | 01:10 PM
  #89
ttt
Old Jan 18, 2013 | 01:36 PM
  #90
bump
