Evo 'For Sale' Suspension / Brakes / Handling Includes pads, rotors, springs, shocks, swaybars, and other handling related components.
Perrin Lower Arm Bar, S-tech, Eibach
Old Sep 13, 2004 | 04:53 PM
Vivid Racing's Avatar
Whoring Out Perrin Lower Arm Bars
Beautiful billet aluminum lower sub frame brace designed with the performance enthusiast in mind. Higher tensile strength helps distribute cornering forces between both sides of factory sub frame. This is a perfect compliment to any 3" down pipe as additional clearance has been added.
Other braces (including the factory installed) must be removed when larger down pipes are used. Also, looks great and is a great finishing touch to any show car undercarriage.
$129 Shipped
Tein S-tech Springs
TEIN S.TECH Spring is an excellent step towards suspension tuning. They offer approximately a 1.9 inch drop up front and 1 inch of a drop in the rear for a more aggressive appearance. Comes with a 1 year limited warranty. Spring length is guaranteed not to sag more than 5mm and to be clear of any manufacture defects
$145 plus shipping
Eibach Lowering Springs
An Eibach Pro-Kit is designed to reduce the fender-well gap by safely lowering your vehicle, giving it a more attractive, sportier stance. The Pro-Kit is the perfect compliment to any vehicle, whether in stock form or fitted with a larger tire and wheel package. The Pro-Kit will set your vehicle off from others, giving it "The Look" you want.
$215 plus shipping
any questions? orders? call me 480.966.3040 ext 226.
jacky
