Affordable Brake Packages Available Now Exclusively Through MAPerformance.com
MAP Stage 1 Brake Package EVO VIII/IX Package Includes
Girodisc "Magic Pads" are the solution to your squeeky, dusty, expensive factory pads. They have less dust than typical factory pads and much less than typical performance pads. Additionally, they have great initial bite, something most less expensive pads are lacking. But the real reason people like our pads so much is they are the "silver bullet" to brake noise problems. Magic pads are a semi-metallic composition that is easy on the rotors and the wallet. We recommend always replacing pads as a whole car set when switching compounds. Included is a set of our Pad Adapters (shims) for the full package. All of Techna-Fit's assemblies are assembled in-house, to stock or custom specifications, meeting D.O.T. Certification. ATE Super Blue (DOT 4) has a dry boiling point of 536F and a wet boiling point of 396F. ATE Super Blue is compatible and will mix with most DOT3, DOT4, or DOT 5.1 Fluids. The overall high dry and wet boiling points make this fluid an excellent choice for street driven vehicles where brake fluid is flushed less frequently than in racing cars. Available NOW for only $239.99 Shipped! http://www.maperformance.com/img/forums/sep3.png MAP Stage 2 Brake Package Mitsubishi Lancer EVO VIII/IX http://www.maperformance.com/images/P/pixel-80.jpg https://www.maperformance.com/image....&ts=1325972695 MAP Stage 2 Brake Package EVO VIII/IX Package Includes
All of Techna-Fit's assemblies are assembled in-house, to stock or custom specifications, meeting D.O.T. Certification. ATE Super Blue (DOT 4) has a dry boiling point of 536F and a wet boiling point of 396F. ATE Super Blue is compatible and will mix with most DOT3, DOT4, or DOT 5.1 Fluids. The overall high dry and wet boiling points make this fluid an excellent choice for street driven vehicles where brake fluid is flushed less frequently than in racing cars. RotorPros rotors offer maximum braking performance in applications with OEM rotor size and stock calipers. They are created from the highest quality (Centric) blanks to ensure the best heat dissipation and superior wet weather braking. The added air surface created by cross drilling, dimpling, and slotting will further increase the rotors ability to dissipate heat, cool your pads and discs, and protect against warping. Available NOW starting as low as $479.99 Shipped |
You guys better make it out to Proving Grounds 2012! Its going to be even more insane this year!
Payday bump!!!
great deal! will be coming back once im ready for this setup
Sounds good!
New week bump!
Late night bump!
Don't forget about our Boost for Boobies event coming up!
Бесплатный высокоскоростной пятерки!
Middle of the week bump!
I'm off tomorrow guys, so if you need anything please email me or you can drop a PM and Chris will get it handled for ya!
Monday night bump!
Midnight Bump (EST)
New week bump!
