Get Your Brakes HERE!!! Hawk-StopTech-DBA-EBC
UPDATE:
Ignition Ready is moving to a larger facility! As of next week we will be taking a break from all of the forums that we post on, to put all hands on deck for the big move. We will be back on here as soon as the move is complete, and have a TON more to offer! You can still order the same parts as always by either calling 631-223-8090 or emailing Sales@IgnitionReady.com for the BEST deals in the industry, hands down. The shipping department will still be functioning throughout the move. Those of you who are familiar with us can still email me directly (Chris@IgnitionReady.com) and I will take care of you. My customers are my customers for life! One thing I can promise, expect HUGE things from us once we are settled in the new building. I'm not revealing anything other than that a 4-wheel dyno may find its way inside ;) Stay tuned for more updates on our website and on our Facebook page. http://i27.photobucket.com/albums/c1...o11-6small.jpg We recently started carrying brake components and purchased a large inventory of pads, rotors, lines, and fluid for Evos. So let me know what you need and I'll get you guys the best deals possible! Almost everything is in stock right now, so it will ship out same-day. Every single person who has purchased from Ignition Ready through me on EvoM is very happy they went with us. We price match as well, so if you think you're getting a deal somewhere else, let me know about it! It doesn't hurt you to shoot me a PM and see what I can do for you. I could potentially save you some good money that could be spent on more parts for your car! We love package deals as well; so if you need a full setup (rotors, pads, lines, and fluid), expect to get an insane deal!! http://i27.photobucket.com/albums/c1...on/IR/hawk.jpg HPS Street Pads
HP+ Street Pads
Performance Ceramic Pads
Blue 9012 Pads
HT-10 Pads (Front Only)
HT-14 Pads (Front Only)
DTC-30 Pads (Front Only)
DTC-60 Pads
DTC-70 Pads
http://i27.photobucket.com/albums/c1...ion/IR/ebc.jpg Yellowstuff Pads
Redstuff Pads
EBC Sport Rotors
EBC Ultimax Rotors
http://i27.photobucket.com/albums/c1...R/stoptech.jpg StopTech Street Performance Pads StopTech Street Performance brake pads are engineered to meet the demands of high performance driving while maintaining the refinement and comfort expected in everyday driving conditions. StopTech brake pads combine the benefits of premium street brake pads with aggressive friction formulas suitable for light track day and autocross use. Para-aramid composites are specially formulated to provide linear response at both cold and hot temperatures, delivering optimum stopping performance over a wide range of driving conditions. StopTech PowerSlot Slotted Rotors Excessive heat can cause resins in your brake pad to vaporize or "outgas." As the brake pad wears, the used friction material turns into a fine dust. This boundary layer of heat, gas and dust builds up between the pad and rotor surfaces and inhibits performance. Here's where Power Slot's slotted brake rotors make a big difference. Power Slot Slotted Brake Rotors are a true performance rotor and feature: * Power Alloy castings (on select applications) - Engineered Performance Rotor - Superior resistance to cracking due to thermal stress - Increased molybdenum (higher carbon)content that extends reliability, service life and helps reduce NVH noise issues - Rotor material is a direct descendant of the patented AeroRotor from StopTech * Introducing directional curve vane design (on select applications) - Improved vane design or OE equivalent on all rotors - Center split castings * New short slot design runs perpendicular to the vane to preserve rotor strength. * Direct OE Replacement * Improved wet weather response * Increased initial bite * Double disc ground for a consistent friction surface and Improved pad bed-in * Mill balanced * Black E-Coated non-friction surfaces on Power Alloy rotors * Enhances open wheel appearance StopTech Stainless Steel Brake Lines StopTech stainless steel brake lines improve pedal feel and reduce the amount of time between applied pedal pressure and actual deceleration by preventing expansion, which stock rubber flex lines allow. This provides a quicker pedal response, and allows the driver to maintain consistent brake pressure and precision brake modulation. StopTech brake lines consist of a Teflon inner line that is covered with a layer of stainless steel woven braid. The Teflon tube is very resistant to expansion under pressure and will not degrade from exposure to brake fluid. The stainless steel braid provides support for the Teflon and the weave is extremely durable against incidental impact and abrasion. StopTech brake lines feature a Clear Abrasion Resistant Cover for maximum protection against chaffing All StopTech Stainless Steel Brake Lines are DOT (United States Department of Transportation) compliant and 100% tested to a pressure of 4500 psi. StopTech STR-600 & STR-660 Brake Fluid Like all StopTech products, StopTech High Performance Brake Fluid is carefully designed to give drivers an edge in the punishing world of high performance motoring. For over a decade StopTech has engineered and delivered race- and championship-winning brake components and systems for high performance street driving as well as pure racing. StopTech High Performance Brake Fluid adds a new dimension to the company's offerings. Available in STR-600 and STR-660 formulations for high performance street and racing applications respectively, the new StopTech High Performance Brake Fluid is a DOT 4 motor vehicle brake fluid, engineered to optimize brake system performance at high operating temperatures. In addition to guarding against boiling and subsequent loss of efficiency at severe racing temperatures, StopTech Brake Fluid maintains its excellent viscosity, lubricity and non-compressibility. StopTech Racing Brake Fluid stands out not just for its exceptional performance, but also for its stylish and functional packaging. StopTech Brake Fluid comes bottled in a special metal container that is not only more durable, but also gives the fluid up to 25 percent longer shelf life than typical plastic bottles provide. Both in looks and in performance, StopTech Brake Fluid stands out from the crowd. StopTech High Performance Brake Fluid conforms to and exceeds the current specification of U.S. FMVSS 116 (571.116) DOT 4, is road legal, and compatible with modern ABS and other vehicle dynamic control systems. StopTech brake fluid is mixable with all DOT 3 and 4 products. *StopTech STR-600 High Performance Street Brake Fluid* * Typical Dry Boiling Point: 594F (312C) * Typical Wet Boiling Point: 404F (206C) * Minimum Wet Boiling Point: 383F (195C) * 500mL metal container gives fluid a 25% longer shelf life *StopTech STR-660 Ultra Performance Race Brake Fluid* * Typical Dry Boiling Point: 622F (328C) * Typical Wet Boiling Point: 404F (206C) * Minimum Wet Boiling Point: 383F (195C) * 500mL metal container gives fluid a 25% longer shelf life http://i27.photobucket.com/albums/c1...ion/IR/dba.jpg DBA 4000 Series Rotors DBA 4000 Series Rotors are a mid-series enhanced performance rotor. These rotors feature Thermal Stability Profiling (TSP) for improved heat handling and Thermo-Graphic paint markings for effective heat monitoring. *DBA 4000 Series rotors are available in slotted or drilled & slotted* DBA 5000 Series Rotors DBA 5000 Series Rotors are a high-series enhanced performance rotors. These rotors feature Thermal Stability Profiling for improved heat handling, Thermo-Graphic paint markings for effective heat monitoring and Kangaroo Paw ventilation which runs cooler, stronger and outperforms traditional straight vane disc rotors by up to 20%. The aircraft-grade aluminum center/hat provides greater resistance to distortion as it allows the disc to expand uniformly. The DBA 5000 Series Brake Rotors are designed for the serious driver. These 2-piece ultra-high performance rotors feature aerospace grade materials for added thermal (heat) protection to you vehicle's wheel bearings. *DBA 5000 Series rotors are available in slotted or drilled and slotted, and with black or gold hats* http://i27.photobucket.com/albums/c1.../goodridge.jpg Goodridge G-Stop Stainless Steel Brake Lines Goodridge G-Stop Brake Line Kits are constructed from the finest quality hose, consisting of a PTFE inner and stainless steel overbraid. Replacing OE brake lines with -03 PTFE hose improves brake feel over factory lines, eliminates sponginess, and provides shorter stopping distances and consistent braking in performance applications. The shorter stopping distances and improved pedal response provide safety features as well as performance advantages. All G-Stop lines go through a nine-point quality assurance testing including the materials tensile strength and 3000 psi pressure ratings. When used with an ABS braking system they virtually eliminate brake pedal chatter. All G-Stops conform to FMVSS106-Federal Motor Vehicle Safety Standard- making them DOT compliant and are TUV approved-the German standard that most international regulations follow. *Features* * Performance Enhancement & Safety Improvement * Eliminates Sponginess Under Braking * Increases Braking Efficiency * Abrasion and Corossion Resistent http://i27.photobucket.com/albums/c1...n/IR/motul.jpg Motul RBF600 Brake Fluid 595°F dry - 421°F wet Extreme high performance polyglycol brake fluid. Far exceeds the standards of DOT 4. The package is filled with Nitrogen, increasing shelf life and eliminating contamination while factory sealed. Extremely high dry boiling point helps prevent vapor lock and brake fade during hard use, with excellent recovery time. PM or call us for current pricing. Mention that you saw this ad and receive the exclusive EvoM pricing and free shipping! 631-223-8090 (Ask for Chris) |
The best deals on brakes you'll find! Think you're getting a deal somewhere else? We'll match it, plus get it to you faster!
All PMs replied, and orders from the weekend will be shipping out today. {thumbup}
Bump for more brake deals!
Great deals on brakes! No need to look anywhere else! Best service and prices in the industry, guaranteed. Aggressive price matching on everything!
Bump for brakes! This sale ENDS when this month is over, I'm absolutely not allowed to have any exceptions.
How much for DTC70s for front and rear?
What about a cheap daily driver rotors for front and rear? Thanks |
All PMs replied! Thanks for the orders.
Month is half over, that means the sale is half over! These are wholesale prices just to increase our customer base in the Evo community, we aren't making a dime on them! If you are familiar with us, you know that we do these sales on certain parts every so often. These are definitely worth it to get in on!
What a perfect day to snag a great deal on brakes! :mitsu:
Find out why everyone else buys from us! {thumbup}
Bump for brakes! {thumbup}
Lots of great deals on going on now!
Bump for great vendor. Installed my DBA4000s last night, look and feel great. Shipped quick and very friendly.
Do you sell Centric Premium rotors?
If so, front rotors only shipped to 94597 please. Thanks! |
