My wing getting stripped :D
Old Sep 30, 2004 | 06:53 AM
mifesto's Avatar
Originally Posted by f86sabre
Mitsu paints the carbon because carbon composites do not like sunlight. I work in the aerospace industry (structures engineer, mainly metal though) and when I bought my Evo I talked to our composite engineers about the naked airfoil. They were really surprised to see it. They recommended I either get it painted or be sure to keep UV protection on it. As areet stated, he’s getting it stripped due to yellowing. That is just cosmetic. After enough time (likely longer than the average life of the car) the structural strength of the part can suffer. Still, I think what you have done to that one looks awfully nice and would go fantastic on a black Evo. I hope it all turns out for you. Just keep a good UV wax on it.
Best wishes,
f86sabre
you stated he is getting stripped because of yellowing, this implies the clearcoat yellows not the carbon fiber itself... so does that mean as long as u strip the clearcoat and spray on a few layers of clearcoat, you can get rid of any yellowing?
Old Sep 30, 2004 | 07:46 AM
sir lurks alot's Avatar
I think the resin itself yellows. Not sure you can do much just by sanding it. I figured Mitsu would have added a uv protecting additive to the resin to prevent the yellowing, but I guess not.
Old Sep 30, 2004 | 07:57 AM
f86sabre's Avatar
You would have to ask areet if the removal of the clear coat totally solved his problem. Yellowing due to clear coat issues could be separate from damage to the resins used in the composite lay-up. Our composites (meaning the ones I see at work) don’t have clear coats, they are primed and painted. I know I have seen areas of carbon composite panels where the paint and primer have come off and you can tell that the coloring has changed due to UV exposure. Of course, my experience is with airliners and they operate in a much harsher environment than our cars. Whatever you do, you want to make sure the wing is well sealed up when you are done. Any moisture getting in between plies can lead to delamination. I don’t know if you would want to disassemble the wing to be sure that you get clear coat everywhere or not. I still think it looks cool. Good carbon work is almost like art.
Best wishes,
f86sabre
Old Sep 30, 2004 | 08:00 AM
sleet's Avatar
Looks sweet!!!
Old Sep 30, 2004 | 01:07 PM
UndieStainz's Avatar
Freakin awesome,...I am doing the same thing, looks way hot.
Old Oct 1, 2004 | 11:41 AM
areet's Avatar
Heres a teaser shot til I can get it installed today
Attached Thumbnails My wing getting stripped :D-glossy.jpg
Old Oct 1, 2004 | 12:04 PM
BADEVO's Avatar
aww c'mon dude
Old Oct 1, 2004 | 12:07 PM
Evo11V's Avatar
Veteran: Army
BOoooooooooooooo!!!!
comon thats not cool, looking good cant wait to see the pics.
Old Oct 1, 2004 | 08:38 PM
inphluence's Avatar
mmm, we have same taste, im planning to get a cf trunk and strip it too, its gonna looks SICK man.. pix pix pix pix pix pix pix!!!!
Old Oct 1, 2004 | 08:43 PM
Kelmar's Avatar
The day is almost up... where are the pics?!?
Old Oct 1, 2004 | 08:57 PM
03EvoVIII's Avatar
Well, let me just state right off the bat that I am a dumb ***. I thought just the center section was only CF. I had my wing broken in half by some vandals (a while ago) and I saw there was foam in the middle I was figuring that the sides were fiberglass at most. But that explains the $1500 cost for a new wing....
Old Oct 1, 2004 | 08:59 PM
johnnysixer's Avatar
THE SUSPENSE IS KILLING ME!!!!!
(yea thats right...caps are necessary)
Old Oct 1, 2004 | 09:18 PM
EVOKing8's Avatar
its fri post the damn pic!! lol
Old Oct 1, 2004 | 10:14 PM
Trail Slide's Avatar
1:14 am, LIES
whats "wet sanding" ?
also what did you do after you sanded off the paint with the 400 grit?
Old Oct 1, 2004 | 11:20 PM
areet's Avatar
Haha, sorry guys. My friend was bringing me the wing, but when he put it in the backseat of the car, he said he chipped the clearcoat. He said he'd bring it to me this morning. Sorry about that guys, I know you were waiting for the pics. Wet sanding is when the surface and sandpaper are wet and you use water as a lubricant or something. After he sanded with 400 grit, he went up to 600 then 800 grit, made sure to wash it, then started spraying clearcoat on it.
