"UN" OFFICIAL WINGLESS EVOS THREAD!!!
Old Apr 23, 2010 | 11:54 AM
  #901
big block ix's Avatar
Originally Posted by aznsouljah04
big_block_ix... very nice car!
I took the picts^ its my friends car, you notice the camera mounted on the roof??
Video (Roof Cam) of the GG Evo on CCW's trapping 102mph:
Same Run:
Old Apr 23, 2010 | 12:13 PM
  #902
wasFWDnowAWD's Avatar
do u know what trunk lip he has? both the GG and RR's were very clean.
Old Apr 23, 2010 | 12:47 PM
  #903
*.jdmevo8.*'s Avatar
i just took off my wing and i like it!!!!looks more aggressive
Old Apr 23, 2010 | 01:04 PM
  #904
AWD OWNZ U's Avatar
Originally Posted by Xenope
Thanks! They are CE28N Genesis 18x10.5 +18 with something like a 30-45mm spacer/adapter front and rear... soo they are actually negative offset...
You are running a 45mm spacer? Uh, do you think that's safe? That's almost 2" man.
Old Apr 23, 2010 | 03:01 PM
  #905
Xenope's Avatar
Evasive's Evo and the Cyber Evo run a similar sized spacer. Mine is custom machined to be hub centric and wheel centric integrated into the spacer itself. I also use a separate set of Kics Neo Chrome extended lug nuts to secure the spacer to the hub.
Old Apr 23, 2010 | 03:25 PM
  #906
Maxedout19w's Avatar
Old Apr 29, 2010 | 07:12 AM
  #907
shh!! sleeping's Avatar
Not to sound like a newbie... but ive been a little puzzled on offsets and spacers and how it works.
from what i understand the lower the + offset the more it makes the wheels stick out to the fenders... But how does spacers work? if i was to run a +12 offset rim i would need a spacer ( i think for clearance of the caliper correct if im wrong) but is that the same as running a +22 offset rim? or is it actually a +02 offset? Im a little confused with how spacers work... sorry to go off topic... PM me to keep the thread clean if you wish
Old Apr 29, 2010 | 08:02 AM
  #908
ElectrIX Blue's Avatar
Originally Posted by Maxedout19w
whats the specs on these wheels??? thanks
Old Apr 29, 2010 | 08:39 AM
  #909
xmaciek82x's Avatar
Originally Posted by big block ix
Anyone know what trunk lip that is. Kinda like it.
Old Apr 29, 2010 | 03:35 PM
  #910
limp_noodle's Avatar
adding a +10 spacer to a +12 offset wheel will make it a +02 offset.
adding spacers lowers the offset.
And to contribute to the thread. My wingless evo
Old May 2, 2010 | 07:57 PM
  #911
jsayers's Avatar
I want to go wingless but I do not want to fill in the holes in case I want to go back one day.
What do you guys recommend using to stop water from getting in?
Old May 2, 2010 | 08:30 PM
  #912
turbologist's Avatar
I would suggest buying my Chargespeed CF trunk...
Old May 2, 2010 | 08:32 PM
  #913
freshjuicebox's Avatar
that gg evo looks amazing! so clean!
Old May 2, 2010 | 09:53 PM
  #914
Old May 2, 2010 | 10:31 PM
  #915
inf0's Avatar
heres mine.
