just got my apr widebody kit
Originally Posted by JDMgrafiteMR
aw man i just came from the shop..they need another week and a half...apparently the kit bubbles up in the sun..like their was air or something inside the fiberglass...they are popping them and bondo-ing it up...does anybody know why the kit would bubble in the sun? when i recieve the kit it was sticky but not wet...is it because it didnt fully dry? (the fiberglass?)
a little offtopic..
I don't know if you've heard of a compound called Fissure(sp?)
It's used to mold fiberglass to metal (like bondo) however the bonding is farrrrr stronger. With bondo if you hit a bump hard enough or shut your rear door hard there's a chance that a crack can form where the bondo molds into the metal. With fissure that don't happen as it's far stronger.
I personally haven't used or seen fissure, but i read a lot of good things about it and heard good reviews from people
Sounds to me like they didn't lay it up correctly. The resin didn't kick proplerly, and there is a chance that it didn't fully cure.
All problems I would NOT deal with on a $4k bodykit.
