black out tailights
Old Sep 11, 2005 | 05:34 PM
EvOwanKenobi08's Avatar
black out tailights
i was just wondering if anybody have a silver evo with the blacked out tail lights because im trying to decide if i should do it or not and i wanna make sure i'll like it. thanks
Old Sep 11, 2005 | 05:42 PM
BoostWhore's Avatar
u mean black out the otter lense. ITs illegal ive seen ppl do it. Cops will prob hassle u
Old Sep 11, 2005 | 05:47 PM
5.slow's Avatar
I used that nightshades spray tint first on my taillights and liked how they came out but I wished they weren't as hazy looking sometimes. The pictures make them look darker then they really were.
I recently switched to a set of Evodave MR tails and I really like the way they look.
Old Sep 11, 2005 | 05:49 PM
5.slow's Avatar
I was never pulled over or hassled when my lights were painted and they were like that for a few months.
Old Sep 11, 2005 | 06:04 PM
what nightspray thing are u talkin about?
Old Sep 11, 2005 | 06:09 PM
jasonn's Avatar
its a can of tint spray thingy. you can get those at like automotive stores.
Old Sep 11, 2005 | 06:11 PM
whats the actual name of it and i can get that sort of thing at like pep boys or w/e?
Old Sep 11, 2005 | 06:13 PM
blueo4's Avatar
link to buy @ summit http://store.summitracing.com/defaul...=egnsearch.asp
Old Sep 11, 2005 | 06:16 PM
gotcha alright thanks
Old Sep 11, 2005 | 06:17 PM
blueo4's Avatar
by the way you have to clear coat it to get rid of the haze
Old Sep 11, 2005 | 06:25 PM
5.slow's Avatar
I did clear them but they were still a little hazy. If I did a set now after doing some before I feel confident that they would turn out better.
Old Sep 11, 2005 | 07:09 PM
what do u guys mean by clear coat and with what?
Old Sep 12, 2005 | 05:23 AM
S2Kstephen's Avatar
Here's another option:
Stickercity.com sells a "smoked tailight kit" that put 35% tint on the tails. Washable, removable, and reusable! $50
http://stickercity.com/store/product...cat=871&page=1
Old Sep 12, 2005 | 06:59 AM
5.slow's Avatar
You can't reuse those once you take them off.
Old Sep 12, 2005 | 07:44 AM
coastal96's Avatar
If you don't know what clearcoat is, I would highly recommend that you do not do this by yourself as you will probably mess up your taillights.
Basically, pretend the Nightshades tint spray is spray paint as it acts more or less the same. You spray it on using several light coats until you get the desired darkness. The can recommends 3 or so coats. I personally think that is too light. On the otherside of the spectrum, I've emptied a can on a set of tails and they ended up being too dark where you can barely even see the taillights when they come on.
After you achieve your desired darkness using the nightshades you have to put a protective coat of clearcoat, which will also make the lights "shinier". However, I found with the clear that you should spray closer to the lights using heavier coats instead of misting the clear like you normally might. You just have to watch out for sags in the clear applying it this way.
