Made Lower Din 3 Gauge Panel
Well I couldn't find anyone making these, and I really wanted gauges mounted in the cubby like the factory ones. So I decided to CNC my own panel from 6061-T6 aluminum, it still needs to be painted. Now I need to buy gauges, thinking of the VDO gauges from 42 Draft Designs. The gauge in picture is my mock-up one from my Talon. Let me know what you guys think.
If you are going to mount the gauges in the cubby, I would angle them left and upward to make them easier to view. In the current position, you won't see the needles' correct reading. -Gabe
Originally Posted by Derek888
doesnt 42 draft design make the same type of panel?
i was thinking about doing something like that...not sure if anyone thought of it...but get an radio relocation kit and get the 42 draft design gauge panel and installed in the cubby hole
Originally Posted by 2literv8eater
Angling would work better if you molded them, but machining an angle would be hard and it would only be a slight angle compared to molding.
It wouldn't really be that hard. Intsead of drilling with the plate on a flat surface, you drill with the plate at an angle..Of course if you are using a bandsaw and drill press/holesaw for "machining" it's really not the same as using some higher dollar equipment.
The 52mm gauges are a close fit to the din height, so getting them angled and making the fit look factory so it doesn't protrude too much at the bottom of the panel may make it look odd. But it may be worth a try
That looks amazing. I for one would be in if the price was right
**edit** thread revival at it's finest. Sorry. Thats what the search button does, brings up old threads lol. I am still interested though
