Help!! Hid light not working
My left low beam hid light went out last week, so I bought a set of 6000k hid bulbs to replace them with. However, when I changed the bulb the light still did not come on. I checked all the fuses and they seem fine. What else could the problem possibly be??
I went to an electrician today and they think its the hid box. Not sure if that is they're same thing as the ballaster but its a silver box right under the HID bulb housing. If not then can somone post a pic of what it looks like??
it wold probably be cheaper to replace the ballast with aftermarket, since you drive a 7 i take it you arent under warrnaty still. Most aftermarket kits come with 2 ballasts wiring etc. so replace them both imo unless you can find a used oem ballast from somebody.
i got mine from blinglights.com i will hook them up next week when i get my lights back, or xenondepot.com there a little more spendy, and make shure you order the right kit if you have oem hid's.
