XM radio install how to
Old Dec 19, 2005 | 07:39 PM
jesterEVO's Avatar
Can someone explain how they got the antenna on the windshield passenger side at the top. ON the roof that is. Also another explanation of how you get it on the trunk...i cant find a way to get it from the inside to the outside ...
Old Dec 21, 2005 | 01:57 AM
eclipseownzu's Avatar
I had to feed the antenna wire under the weather stripping for the back window. I was pretty much a pain in the a$$, but it looks great now. It also worked much better than the magnetic window mount model I tried originally. You should put the antenna on the roof, the wing will interfere with the signal if you put it on the trunk. (unless you have an RS of course)
