The Real SSL and Vortekz Generator
Old Jan 1, 2007 | 08:15 PM
  #31
OneillEvo's Avatar
Nice job on the dash. The vortekz thing looks pretty neat. How much did you spend on it?
Old Jan 1, 2007 | 09:34 PM
  #32
J8dailo's Avatar
parts for dash plus vortekz generator about $45... can't beat that!
Old Jan 2, 2007 | 03:34 AM
  #33
kyuno_evo's Avatar
damn give this guy a F**king break. Why all the negative comments....who cares if it looks off or whatever. Its his own car, he can do whatever he wants to it. lol
Old Jan 2, 2007 | 06:20 AM
  #34
Yme's Avatar
Yme
Not too bad
Old Jan 2, 2007 | 06:36 AM
  #35
o-townFLA's Avatar
Originally Posted by J8dailo
from what i read...those were also wind tunnel tested thus angle recommended.. im not sure how accurate this is but can be questionable...this came straight from the website...
This is actually from an EVO manual^^^^
And if he post on here wanting comments on his ride he'll get 'em. He only asked for what he wanted...
Old Jan 2, 2007 | 10:18 PM
  #36
jkim2001's Avatar
Hahaha, what you are seeing is a direct translation of Mitsubishi's OEM vortex generator wind tunnel testing. You were suckered...
Old Jan 3, 2007 | 07:26 AM
  #37
Jakeg97's Avatar
not feeling your vg
Old Jan 3, 2007 | 07:31 AM
  #38
purevibez's Avatar
dash is nice. th vg is diffrent from the ones every one else has
Old Jan 10, 2007 | 09:03 AM
  #39
soloevo8's Avatar
Originally Posted by revvin9k
Thats not even close to the way it sould be. You have too many fins. Just like someone said earlier, a lot of R&D were put in the VG, yours kinda looks ricey. Why not just get the real thing? You can see how off it is when you compare pics.
He is not blind you took the picture from a different point. As you can see his pic is from about 5ft. away yours is from 20ft. away that will make the angles look completely diff. The data used to make the Vortekz VG' is based on Mitsu's design and testing. They got all that info 1st from airplane VG’s. It was nice of them to offer that test PDF that proved the idea works. Yes they did the wind tunnel testing not Vortekz, we are adding a disclaimer to that image as we speak. To be honest the more research I have done the more I am finding out that you could put some folded business cards at a 15 degree angle on the car 100mm before the air flow separation as long as they are not causing drag (over 25mm tall) they will still do the same thing.
According to research I have done your bulky fatter vg's will not do as good of a job as the Vortekz models, they slice the air much better and will cause less drag. As you can see in the Mitsu PDF doc the more bubbly the VG is the worse of a job it does of creating a good vortex. Making functional VG’s universal for any car like they do with airplanes is mainly why I came up with these.
Matt
Vortekz.com
Old Jan 10, 2007 | 09:11 AM
  #40
NY Evolutionary's Avatar
You spent $30K+ on the car , but you did'nt want to spend $100 on the VG?
Old Jan 10, 2007 | 09:14 AM
  #41
mot's Avatar
mot
i like the oem piece i just wish it stood out a little more
Old Jan 10, 2007 | 09:23 AM
  #42
reggiesd's Avatar
i guess those things don't look half as bad...atleast it's on an evo.
Old Jan 10, 2007 | 09:28 AM
  #43
evleb's Avatar
leather is awful!
THE VORTEX LOOKS good but i beleive their positions are wrong
Old Jan 10, 2007 | 09:31 AM
  #44
evolved83's Avatar
those look tacky. do yourself a favor and get a real one. its 99$ for an oem vg from rexpeed and that is painted and shipped... its really not that much man.
Old Jan 10, 2007 | 09:35 AM
  #45
evo637's Avatar
Originally Posted by o-townFLA
I would have looked into this a little more. All the research that was put into the VG actually does something. So if you just put any type of pattern on it will defeat the purpose of the VG.. in my opinion
+1
