Apexi Rx6
Old Feb 15, 2007 | 07:24 AM
  #31
mot's Avatar
mot
its winter
she hasnt even been started yet
its good for 550hp they say
this is the same turbo the cyber evo runs
so i dont think its too small
at what rpm do you hit full boost on your 3065?
because the people i talk to say its about 34psi at 4600 rpm with this turbo
Old Feb 15, 2007 | 07:44 AM
  #32
bvdawg13's Avatar
Ya, it looks like it would spool quickley
My 3065 is hitting full boost at about 4800
I heard the Rx6 was rated at 500 but i have never actually seen one on an evo
You can check out my dyno sheet on Buschur's mustang
https://www.evolutionm.net/forums/sh...d.php?t=249325
Old Feb 15, 2007 | 07:09 PM
  #33
gaijin's Avatar
Originally Posted by mot
its winter
it is rated at 550hp and should make about that. The Cyber Evo runs a heavily modified version of this turbo with the p25 hotside I believe.
It's not that small at all and it is incredibly efficient.
Good luck with the manifold though. I went through three of them and even tried welding on more supports to no avail.
Old Feb 15, 2007 | 07:11 PM
  #34
trjx24's Avatar
nice kit dude.. good luck with it
Old Feb 15, 2007 | 07:23 PM
  #35
version 2 beta's Avatar
make sure to get a map/tune on 120 octane race fuel! You will truely see how bad a$$ that turbo is. Btw cyber evo runs the same octane and pushes 700 out of that turbo!
Old Feb 15, 2007 | 07:29 PM
  #36
mot's Avatar
mot
i heard you had manifold problems running on a 4g64
which has a taller deck height which didnt help your issue
anything happens ill def a custom manifold
also i beleive the cyber evos turbo is unmodified
Old Feb 15, 2007 | 07:46 PM
  #37
ries's Avatar
wow...thats a great looking kit, what type of #'s you expecting to see?
Old Feb 15, 2007 | 09:31 PM
  #38
mot's Avatar
mot
~500 as is
Old Feb 15, 2007 | 09:34 PM
  #39
1NastyEvo's Avatar
toooo sick.
Old Feb 15, 2007 | 10:49 PM
  #40
4G63's Avatar
Nice lookin kit...now get it installed ASAP!!!
Old Feb 15, 2007 | 11:06 PM
  #41
black CT9A GSR's Avatar
looks good everything you have there, bet it will show some nice results out there on the track once it's finished.
Old Feb 15, 2007 | 11:09 PM
  #42
Speed Element's Avatar
baller status!!! nice kit!! I want this kit for my evo so bad!
Old Feb 15, 2007 | 11:25 PM
  #43
Rexpeed's Avatar
baddass kit!
Old Feb 15, 2007 | 11:27 PM
  #44
Top_End_EVO's Avatar
why does having a taller block effect the manifold to crack? i dont understand...
Old Feb 16, 2007 | 06:03 AM
  #45
High_PSI's Avatar
It is a real nice kit, just make sure that the Manifold is the latest design, the earlier units did crack. I am also confused about the water cooled waste gate, that thing is weird.
