Rota P45R Wheel thread!!
Alright guys, I know this has been brought up a billion times, but I haven't found the answer for the what I'm looking for. I'm wanting to know before I order these wheels, if they will fit my car for sure.
I'm looking at getting some 18x9.5 +30mm offset Rota P45R's, in either Hyper Black or Sport Bronze, for my Lightning Yellow Evo.
I will be running 255/35/18 Dunlop Direzza Z1's and stock suspension. I do not plan on lowering my car. I know I will have to run a 8mm spacer up front and do extended lug studs.
I've read so many different posts that say I will have to roll my fenders, and others that say I will not have to roll my fenders
What I want to know, is if this setup will require rolling of the rear fenders on stock suspension?????
Thanks guys,
Scott
Thanks guys,
Scott
These are probably my favorite wheel for an evo... unfortunately I think many of the wheels ppl put on evo's look like crap
but thats just my opinion.
Ordering a set 18x9.5et20 flat back w/ 255/35/18's this week
but thats just my opinion.Ordering a set 18x9.5et20 flat back w/ 255/35/18's this week
I just bought it in 18x9.5 same tires but 245/40 on stock height and it rubs in the front but not really on the back although if I go on a speed bump, it seems like it bounces in the rear hitting something but it could be my shocks going out x.x I didn't need any spacers for front tires also as it clears the brembo brakes well. Offset is +22
My results are.......... No rubbing up front at all on stock height. In the rear no rubbing anywhere unless you have a trunk full of luggage, or are riding people in the back (only rubs over bumps at speed.)
I was bored and wanted an optional look, so i got a set of ROTA P45R's 17x9 +25 and some TOYO Proxes tires 255/40/17
Need to do a little fender rolling just in case, and maybe a tad raise on the rear CO's.
Still have my 2 sets of oem BBS for the track with A048's , so I can always go back and forth.
Thanks to WheelDude (Dan/Zoeb) for a great Price on them.
Are you using and spacers up front to clear the brembos? If so what size? Did you end up having to roll the rears?
