255/35/18
I have the fender mod in the front, rear is pulled alittle
lowered on coilovers, i just looked at it and driver side is -2 and pass -3 camber( thats no good!)
im rubbing in the front bad, like i cant take a turn at any descent speed at all
heres a picture of it now
https://www.facebook.com/photo.php?f...type=3&theater
rota grids 18x9.5 (i believe +20)
255/35/18
255/35/18
255/35/18
255/35/18
255/35/18
255/35/18
If you want to keep it at your current height, try putting your dampers set on the hardest to reduce roll.
Thats what i had to do
255/35/18
255/35/18
I have same Rota Grids with 5mm spacer in front and 265/35/18 tires. You need to space out those fenders immediately (if you haven't) because you're probably rubbing on the outer fender and linings on turns. I'm -2.1f, -1.5r
Or, if you are herrafrush, then you have man tires on right now and need kiddy Honda tires. Try some 225's on for size.
