Took the Jag out of storage (some crappy pics with the evo)
Or a black car?
White is one of the easiest, if not the easiest to keep clean.
Black is by far the hardest.
Lots of sports cars were like that, quite a few accually that only recently fixed that problem. Ferrari's imparticular were notorious for this. As long as your moving it's not an issue.
I take it you've never owned a white car?
Or a black car?
Or a black car?
awesome pics.... that black/white one is the best! haha.... how much is that jag worth anyways? what are the specs on it?
oh and i like how you took the mitsu diamond off the front...
DATA:
Engine Dimensions:
Cylinders.................6
Bore........................83 mm
Stroke.....................106mm
Cubic capacity.........3,442 c.c.
Piston area..............50.4 sq. ins.
Valves......................Overhead (twin o.h. camshaft)
Compression ratio...7 to 1
Engine Performance:
Max. b.h.p...............160
at................5,000 r.p.m.
Max. b.m.e.p...........140 lb./sq. in.
at................2,500 r.p.m.
B.h.p per sq. in.
piston area...3.175
Peak piston speed,
ft per min.....3,490
Engine Details:
Carburetter.............Two SU horizontal
Ignition...................12-volt coil
Plugs......................Champion NA8
Fuel pump..............Two SU electric
Fuel capacity..........15 gallons
Oil filter..................Tecalemit full-flow
Oil capacity.............3 gallons 1 pint
Cooling system.......Pump,fan and thermostat
Water capacity........3 gallons 1.5 pints
Electrical system.....Lucas 12-volt c.v.c.
Battery capacity......64 amp./hrs.
Transmission:
Clutch....................10-in. Borg and Beck
Gear ratios:
Top..................3.643
3rd...................4.98
2nd..................7.23
1st...................12.3
Rev..................12.3
Prop. shaft.............Hardy Spicer
Final drive..............Hypoid
Chassis Details:
Brakes........................Girling hydraulic (2 LS on front)
Brake drum diameter..12 ins.
Friction lining area.....184 sq. ins.
Suspension:
Front..........................Independent (torsion bar)
Rear...........................Semi-elliptic
Shock absorbers.........Hydraulic
Wheel type.................Bolt-on disc
Tyre size....................6.00x16 ins.
Steering gear.............Burman high-efficiency
Steering wheel...........18 ins.
Dimensions:
Wheelbase.................8 ft. 6 ins.
Track:
Front.........................4 ft. 3 ins.
Rear..........................4 ft. 2 ins.
Overall length...........14 ft.
Overall width............5 ft. 1 in.
Overall height...........4 ft. 2 ins.
Ground clearance.....7 1.5 ins.
Turning circle...........N/A
Dry weight................22 cwt.
damn... thats just nutty! VERY cool car.... just hope your son like cars as much as you do lol.... also, I figured its be worth somewhere around $100-200k... it looks like the red jag in that movie money talks.. with chris tucker/charlie sheen haha
