LED map + dome lights
Old Apr 19, 2007 | 04:23 PM
turbochrgdbeast's Avatar
Originally Posted by SICK9
beast - you just pop the map light cover off with a small flathead and unplug all 3 bulbs, then you plug each led set in it's place, then put them in the space where the orig. bulbs were, -- very easy.
yea, i already popped the light cover in the past but i cant remove the bulb out from it. im referring to the light in front not the dome in the middle.
Old Apr 19, 2007 | 04:29 PM
dizhungryguy's Avatar
nice man
Old Apr 19, 2007 | 10:17 PM
SICK9's Avatar
yea, it was kinda of a pita to get those 2 map lights out on each side, but you can do it.
or get someone with small fingers to try.
I had to kinda twist around in the drivers seat looking back to reach it.
thx...
Old Apr 19, 2007 | 10:26 PM
2dcurb's Avatar
wow those are bright!
Old Apr 19, 2007 | 11:24 PM
xLaNcErEvOx's Avatar
i did the same. i like my white leds on my license plate, looks alot nicer.
Old Apr 20, 2007 | 11:06 AM
SICK9's Avatar
I'm waiting on the License plate LED's right now -[backorder]
As of now I have:
Map lights, Dome light, and Trunk light
all with LED's from there..
License plate leds will be here soon.
Old Apr 20, 2007 | 07:40 PM
boostless's Avatar
those are bright! It make one-time feel more comfortable when you get pulled over. Do they have different colors? Like amber?
Old May 17, 2007 | 11:43 AM
Mach V Dan's Avatar
The difference between the two parts (room light and map light), and reason for the large price difference, is that the map light unit is three panels:
The dome light is only one panel, so it's less expensive. NOTE: Cars with sunroofs do NOT have dome lights! Only the front map light three-lamp fixture.
Heh! I mean...no idea what you mean.
They do not come in different colors. Only white.
We stock them now, by the way, HERE.
--Dan
Mach V
MachEVO.com
Old May 17, 2007 | 02:32 PM
rjdevo9_mr's Avatar
So I found this site online that makes LED lights for the interior of our cars.
www.leddomelight.com -- anybody seen these?
I bought the map + dome lights and let me just say they are sweet.
It is so Bright.
It is like HID's for the interior. makes it light up bright white instead of the dingy yellow light look.
Thinking about getting the trunk and license plate led's also.
Super easy to install and fit like a glove.
Just take old bulb out and plug these in , that easy..
Map light came with 3 different sets of led's, so all bulbs are switched to led's.
And dome light was one big panel of like 12 leds.
Definately worth it.
So just throwing out the info... ltr..
those l.e.d.'s are bright!
Old May 17, 2007 | 03:16 PM
TwStDeVo's Avatar
where can you get the trunk and license plate lights? dont see it on their web site.
Old May 18, 2007 | 07:57 PM
Mach V Dan's Avatar
We have them, HERE and HERE.
--Dan
Mach V
MachEVO.com
Old May 18, 2007 | 08:30 PM
TwStDeVo's Avatar
--Dan
Mach V
MachEVO.com
i see you guys now added them to your site, which is what i was waiting for. definitely will be placing an order now. thanks once again Mach V!
Old May 18, 2007 | 11:17 PM
boostless's Avatar
those are bright! Itll make one-time feel more comfortable when you get pulled over. Do they have different colors? Like amber?
I meant that if you ever get pulled over, having plenty of light will make the cops feel comfortable. It was a random stoney comment...
Old May 19, 2007 | 04:50 AM
jkim2001's Avatar
subscribed
Old May 24, 2007 | 08:48 AM
EVOIX_LMS's Avatar
--Dan
Mach V
MachEVO.com
any pics of the sidemarkers?
