Wire Tucked Engine Bay Pics
Old May 16, 2007 | 12:16 PM
Sir Lancelot's Avatar
Thumbs up Wire Tucked Engine Bay Pics
Let me know what you think...
Before:
After:
Old May 16, 2007 | 12:21 PM
FiftyFive's Avatar
Noice, where did you tuck them? Oh and i finally got those Ings parts painted and put on. Looks awesome, and the fit on the bumper was spot on!
Old May 16, 2007 | 01:11 PM
mdRSX06's Avatar
Do you have a before picture from the same angle?
Old May 16, 2007 | 01:13 PM
918Evo's Avatar
very clean
Old May 16, 2007 | 01:17 PM
SickSilverNLow's Avatar
nice.....
Old May 16, 2007 | 01:20 PM
hondafan's Avatar
yeah, it'd be cool to compare side-by-side.
Old May 16, 2007 | 01:28 PM
Updated with Before/After shot for comparison. Its the closest I have to the same view with the same mods in both pics...for the most part.
Old May 16, 2007 | 01:31 PM
Pics don't work on BEFORE shot....
Old May 16, 2007 | 01:35 PM
ambystom01's Avatar
How did you reroute the throttle cable?
Old May 16, 2007 | 01:36 PM
O3EVO's Avatar
Just moving the throttle cable make is look so much nicer. That's all I did, it's too easy not to do it...
Old May 16, 2007 | 01:41 PM
Kerr's Avatar
Fomer Vendor
What did you do with the coolant and PS reservoir's?
Old May 16, 2007 | 01:44 PM
O3EVO's Avatar
This might get a little strange. Takeand loosen the brackets holding the cable to the valve cover. Then take the throttle cable in your left hand right behind the oil filler cap. Then with your right hand take the cable at the front of the valve cover. Then flip the cable with your right hand over your left, then tuck it under the sturt bar and you are done. Real simple, and I'm an idiot...
Old May 16, 2007 | 01:48 PM
Coolant reservior is hidden under my intake and the PS is tucked tight to the passengers side headlight and dropped about 5 inches.
Old May 16, 2007 | 03:10 PM
hondafan's Avatar
so no brackets hold it, it's just kinda twisted up under thw strut bar? hard to picture the method you said to use.
Old May 16, 2007 | 03:51 PM
BlackSport350's Avatar
You can actually take the bracket the used to hold the throttle cable to the front of the valve cover and attach it to 10MM bolt the is just below the center bracket of the strut tower brace. This will hold it in place and looks pretty factory. The rest of the cable just sits loose.
