JDM ix bumper-degraded handling??
............................................______ __
..............?.....__............................ .............:`.........../
............./__.(.....“~-,_..............................,:`........../
.........../(_....”~,_........“~,_....................,:`..... ..._/
..........{.._$;_......”=,_.......“-,_.......,.-~-,},.~”;/....}
...........((.....*~_.......”=-._......“;,,./`..../”............../
...,,,___.\`~,......“~.,....................`..... }............../
............(....`=-,,.......`........................(......;_,,-”
.............\`~.*-,.....................................|,./.....\,__
,,_..........}.>-._\...................................|........... ...`=~-,
.....`=~-,_\_......`\,.................................\
................................`:,,.............. .............`\..............__
........................................_\........ ..._,-%.......`\
...................................,<`.._|_,-&``................`\
Works great during turkey hunting season.
Contrary to what the other people are making fun of, I believe it does make a difference if you remove your crash bar.
The bar is steel and connects the two frame rails at the rear end. Without it, it's very pliable sheetmetal. True, there are other points that tie it together, but it's like a strut tower bar. The more connections you have, the stiffer it is.
It's also similar to welding in a roll cage etc.
But in the overall picture, removing the crash bar won't really do anything to your car.
And if you get the JDM rear you will get more ***** so I guess that outweighs any sort of handling depreciation.
