My WW IX RS
Old Jul 26, 2007 | 10:22 AM
  #31
Robevo RS's Avatar
Originally Posted by Gsxtremedsm
Are those the gunmetal 18 raze r74 rims from edge racing? If so what exact size and offset are they? What tires did you go with.. and how much do they weigh(if you happen to know).
BTW looks good.
Nope .They are Enkei OR52 . SIze is : 18-8.5 / 35 if i remeber right about the off set.
The tires are Toyo R1 size 245/18 /40
each rims with tires weight aprx. 25 lbs . I weight them almost 2 years ago so i do not remember exactly. So + - 1 lbs.
Old Jul 26, 2007 | 10:26 AM
  #32
Robevo RS's Avatar
Originally Posted by Dorikun
That lip and those photos are EXACTLY what I've been looking for... is that the APR fiberglass lip? how sturdy is the construction? does it look like it will handle daily driving?
yes it's an APR front lip. I'm not really happy for the strenght for that front lip.
yes it is fiberglass. So easy to fix
,wich is i assume, will be very offen.
Old Jul 26, 2007 | 10:36 AM
  #33
Robevo RS's Avatar
Originally Posted by Rudager
Nice Setup...love the letters on the wing and hood pins and everything
Where'd you get the front Red Mitsubishi emblem??
i cut it out. you can do it its so easy. Get a 3M vinyl and one ultra sharp blade. cut out one square, witch is covers one diamond.
Wash the mitshu sign with rubbing alcohol and put the stickers on it.
Then push the sides down so you can see the shape of the diamond.
and start cutting from inside to out side .Dont push the blade too much down so you will not cut the paint.
and repeat it untill you done.
Let the diamond shape drive your blade. Bealive me once you get it ,to do that takes 10 minutes . And always you can replace it, if its got damaged.Rocks etc.
And it will cost you less then $5.
Old Jul 26, 2007 | 10:39 AM
  #34
diegoalunan's Avatar
nice...
Old Jul 26, 2007 | 10:43 AM
  #35
TheDriver11421's Avatar
Originally Posted by ODUB
okay, the wheels are horrible, but the rest of the car is nice. that lip is huge though. and what's the deal with pins on a stock hood? if that's painted carbon, then it makes sense.
Why are his wheels "horrible"? Maybe they're not your taste, but horrible?
Old Jul 26, 2007 | 10:44 AM
  #36
Robevo RS's Avatar
Originally Posted by turbochrgdbeast
well done...nice setup. what does the symbols means on the wing? can anyone translate that?
mitshubishi.
i swear. I got japanise friends ,from japan.
the RS sign from akimoto .
Old Jul 26, 2007 | 11:04 AM
  #37
ODUB's Avatar
i was going to say that maybe horrible was too strong of a word just based on looks, but now that it's revealed that they weigh 25lbs each, horrible stands.
and what's with the pins on a stock hood?
Old Jul 26, 2007 | 11:15 AM
  #38
they weigh 21 lbs.
http://www.edgeracing.com/wheels/enkei_wheel/
Hood pins i'm not a fan of, but thats his style so more power to him.
Old Jul 26, 2007 | 11:23 AM
  #39
svtkiller's Avatar
Where did you get the under tray ?
Old Jul 26, 2007 | 11:32 AM
  #40
nice seats
Old Jul 26, 2007 | 03:33 PM
  #41
Robevo RS's Avatar
with tires...
when i did weight them, they was around 2.5 pound heavyer then the stock 8 rims + tires.
Enkei OR 52 18-8.5/35 $150 each
Toyo T1R 245-18/40 $175 each
i dont think is that horrible. Specially when the whole set up cost around $ 1300...
but that is all about taste.
Old Jul 26, 2007 | 06:34 PM
  #42
W0459732's Avatar
very nice lookin rs, i thought rs has no ac
Old Jul 26, 2007 | 06:40 PM
  #43
nyaegermeister's Avatar
clean clean clean ride.
Old Jul 26, 2007 | 09:49 PM
  #44
Dorikun's Avatar
They jas jelli use! haha j/k j/k, don't mind the bad comments, only the good ones count. Its YOUR car, that's what counts.
Old Jul 27, 2007 | 07:49 AM
  #45
Robevo RS's Avatar
thanks,
