CF Doors.
Old Jul 26, 2007 | 04:13 AM
FloopyDisk's Avatar
CF Doors.
Alright, did a little searching, but couldn't find the information I was looking for. Has anyone used these? If so, what was your weight savings? Not site I've found or post has that listed.
Old Jul 26, 2007 | 05:45 AM
Duderotomy's Avatar
the seibon cf doors are a 20% weight savings over the stockers...
assuming thats what you're referring to
Old Jul 26, 2007 | 05:58 AM
FloopyDisk's Avatar
Yeah, that's what I was refering to. Thank you, do you know what the doors weight in lbs?
Old Jul 26, 2007 | 06:11 AM
justboosted02's Avatar
much cheaper than cf doors
Old Jul 26, 2007 | 07:39 AM
FloopyDisk's Avatar
Damn, does that came in 1x1 or 2x2?
Old Jul 26, 2007 | 08:00 AM
05blackevo8's Avatar
We put them on our DTM/Revision race car. They save a TON of weight compared to the stock doors. There are issues with installing them tho. The rear doors come with belt moldings and the fronts use the factory ones, so that doesnt look right. All in all, i would say that they are for Race Car use only.
Old Jul 26, 2007 | 09:30 AM
mr soul's Avatar
are the stock evo doors alum?
Old Jul 26, 2007 | 09:34 AM
MondoBongo's Avatar
steel i believe.
i am only guessing, based on the fact that i have magnetic number plates for autocross that stick to the door.
Old Jul 26, 2007 | 09:37 AM
Roldy's Avatar
+1 for steel.
I don't think it would be very safe in a side impact collision if the doors were made of aluminum.
Old Jul 26, 2007 | 09:46 AM
JondemandBrende's Avatar
JUN makes CF doors. They are not on the market but can be made one-off for you. We can also get FRP doors from J-speed and Cruise Power.
Old Jul 26, 2007 | 11:33 AM
06blkevo9's Avatar
damn even if you consider putting CF doors on a daily driver, I think you should consider what would happen if you were in an accident, that CF will ready do you damage.
Old Jul 26, 2007 | 11:34 AM
06blkevo9's Avatar
Old Jul 26, 2007 | 11:46 AM
Paulnsx's Avatar
isn't CF stronger than steel???
Old Jul 26, 2007 | 11:52 AM
Roldy's Avatar
I think it depends if they use Kevlar or not. And I'm sure other things are to be considered such as mat/woven, type of resin used, size of CF, # of layers, whether it's been vacuum sealed/curing process, etc.
Old Jul 26, 2007 | 11:58 AM
OKIX's Avatar
my father has carbonfiber doors on his evo ix. He saved a total of about 70lbs by doing so. For pictures just look up his member name 9sec9
